585,971 active members*
4,238 visitors online*
Results 1 to 4 of 4
    Replacing NEMA motors.
    Hi All.
    My Y axis motor makes whining noises after it stops moving. It's a NEMA 34. Sort of a high pitched noise for a second or two.
    Not complaining as I literally put thousands off hours on the machine and the motors aren't expensive. I'll replace it.
    Just curious if anyone had noticed similar issues.
    Dec 2003
    24221
    Re: Replacing NEMA motors.
    Sounds like motor tuning, or something mechanical has changed, such as motor load has changed since original tuning?
    Albert E.
    Mar 2003
    35538
    It may be the drive rather than the motor.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jan 2010
    77
    Start swapping parts. Swap the drives and see if the issue changes. Also remove the motor from that axis and see if it moves freely or if something is wrong there. Steppers usually don't fail, so I would swap those last.
  1. Any advantage to replacing DaVinci stepper motors?
    By dixdance in forum Techno CNC
    Last Post: 03-08-2018, 05:58 PM
  2. Will 2 nema 17 motors(42Ncm Each) be used as one nema 23
    By Haitem56 in forum Stepper Motors / Drives
    Last Post: 08-19-2016, 04:19 PM
  3. replacing motors
    By skylanehku in forum Stepper Motors / Drives
    Last Post: 07-16-2012, 09:16 PM
  4. Replacing Step Motors
    By Jetleg-Jazzman in forum CNC Machining Centers
    Last Post: 09-11-2009, 08:58 PM
  5. Replacing nema 42 steppers with servos
    By bseibenick in forum Servo Motors / Drives
    Last Post: 05-04-2008, 04:47 AM
