585,735 active members*
4,733 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Retrofit Prolight 5000 (Benchman 5000) to run Mach
Page 1 of 2 12
Results 1 to 20 of 26
    Jan 2012
    17
    Hey guys and gals,
    I'm looking to retrofit my newly aquired Prolight 5000 (Benchman 5000) to run Mach 3.
    I received 3 whale3 drivers and a parallel breakout board with it.
    I'd like to get some ideas if using these Whales would be the best route to take or buy newer drivers.
    Spindle control is one of my concerns and not completely sure how to control it and get the speed control to Mach.
    Thanks!
    Nov 2009
    4415
    Re: Retrofit Prolight 5000 (Benchman 5000) to run Mach
    Are you sure a Prolight and a Benchman are the same? I thought the Benchman had a full enclosure and tool changer.
    Since you have everything there to get movement, I would try with what you have. I see the power supplies. How about a few more close ups of the electronics?
    What issues are you having in regards to spindle control? Do you have it wired up and set up correctly in Mach? Relay control?
    A lazy man does it twice.
    Jan 2012
    17
    Quote Originally Posted by Fastest1 View Post
    Thanks for the reply Fastest
    From what Ive found, the Benchman was made by Prolight. Same machine minus the ATC. My machine shipped with the enclosure yet was removed at some point.
    Its currently run by an Acramatic 2100. It's pretty quirky and I'd rather update it before I loose a hardware component as well as making it a bit more streamlined.
    I got 3 Whale3s and a breakout board with it but was leaning towards using currently supported hardware such as the Gecko 320x and a C11 but wanted other opinions.
    C11 ? 6 axis, Multifunction CNC Breakout Board with Relay and Spindle Control | Automation Technology Inc
    I wasn't sure if the breakout board would be able to control the onboard spindle controller.
    Spindle Controller:
    Main Board:
    Servos:
    Whale and current Drivers
    Nov 2009
    4415
    I am sure the interface with the spindle control (Minarik) would be easy.
    Jan 2012
    17
    Ok guys,
    I decided to go with the Gecko 320x's and a C11 BOB. I now have those on hand.
    I plan to use the spindle motor, speed controller, servos, encoders, and PSU that are on the unit ATM
    I plan to share as much info as I go along as this is a bit of a pain, well at least to me as I've never done much of this style work. Hopefully it will help others as they convert their older machines.
    I've found that Intelitek, the company that purchased Light Machines, shares ZERO info about these older, non supported machines. They have but will NOT release any wiring info on them. Oh well...
    Here's what I have in my machine:
    Speed controller: Minarik Z1BOSS15AC-1Q-0596
    Spindle Motor: Eastern Air DB34D-62a
    Servos: Litton C23-L50W10M09
    Encoders: Computer Optical Products CP 550-1000-LD 1396
    PSU: Transformer:Toroid 5549 - Input: 110v AC Output: 55v AC
    Choke: 7062
    I've got a hold of most of the manufactures of the components to get their manuals for each unit.
    I'm building a wiring diagram at the moment and will post it once I have it all together
    Jan 2012
    17
    Ok guys, I got most of the stuff that is not staying pulled out and wired up the PSU to test the output.
    I created the wiring diagram for the servo PSU. Still working the the rest.
    I also wired up the Gecko G320x to the C11 and a servo and encoder to the Gecko. Mach is installed on the PC. I don't seem to be getting any signals to the board C11. I'm pretty sure they are making contact as Mach resets when the power is pulled from the C11.
    When I boot up the C11 almost all LEDS light up and when Mach loads the input LEDS all go off. I can also hear the relays click once Mach loads.
    I've got a 5v and 12v PSU on the way to power the Minarik and C11 outputs.
    Nov 2009
    4415
    Charge pump?
    Jan 2012
    17
    Charge pump?
    I actually disabled it. I forgot to add the pic of when Mach loads.
    The pic with just the USB power LED is when only USB power is added and non other.
    The pic attached is when 5v is added and after Mach loads
    Jan 2012
    17
    Ok guys and gals,
    I got the machine running. Well, all Axis. I canned the OEM encoders and went with AMT-102v's and that solved all my pulsing. I'd still like to test the factory encoders at a later date.
    I now need to wire in my speed controller for the spindle motor.
    I've got 2 relays on the C11 I can use but from the Speed Controller diagram, it appears I need 3 and I'd like to use one to trigger a larger relay used to provide AC power to the speed controller.
    Should I use the floating voltage signal or potentiometer?
    Are the VPOTs only needed with the potentiometer? They are already wired to my spindle more when I got it but wasn't sure if it's better to go with the potentiometer or 0-10v.
    Info on the speed controller:
    http://www.minarikdrives.com/descrip...t/250-0224.pdf
    I'm open to opinions.
    Thanks!
    A video of the machine running.
    Nov 2009
    4415
    Congrats. It looks like it is running smoothly too. It will be a nice machine.
    May 2008
    1185
    Must be nice to see it run.
    What frame size is the spindle motor? Do you know much about it?
    youtube videos of the G0704 under the name arizonavideo99
    Jan 2012
    17
    Feels great. I still need to fine tune it, rewire control box, and get the spindle running with Mach but I'm pretty happy so far.
    Here's the spec sheet on the motor.
    Click to enlarge
    Feb 2010
    3447
    I have the ProLight 3000 lathe that I've been thinking about converting..
    Nov 2009
    4415
    Lets see the right side of the miniark. I want to see where the pot hooks up.
    Jan 2012
    17
    Not sure where you'd like a pic of. Can you explain a little more?
    Quote Originally Posted by diyengineer View Post
    I'd do a conversion again. My biggest issue was the encoders. Once I decided to get new ones all problems were solved.
    Quote Originally Posted by arizonavideo View Post
    I just noticed it was you Arizonavideo. If i get a G0704 I'll surely get your mount kit. They look great!
    More great news!
    I got the speed controller figured out and wired up.
    Nov 2009
    4415
    When I posted for the extra pic, I was looking at the minarik catalog trying to find that model. I finally realized you had unplugged a stackable component. Confusing my ability to determine which model you had.
  17. #17
    Jan 2012
    17
    I see. Thanks for trying.
    I did a little cleaning up of the wiring lastnight. Sadly, this machine will be put up for sale once I get it all cleaned up and running again. I purchased a 2nd hand UMC-10 and the wife says no to 2 machines. I was really looking forward to building the PDB and using TTS holders.
  18. #18
    Nov 2009
    4415
    Oh how I pity you now! A UMC 10? 1 of Dave's machines?
  19. #19
    Feb 2010
    3447
    Public Surplus: Auction #1328701
    Kinda last minute but if anyone wants one..
  20. #20
    Jan 2012
    17
    Yes a Fadec UMC-10. One of Dave's machines. It's gonna be rough but I'm sure I'll survive with it.
Page 1 of 2 12
  1. Prolight Intelitek or Benchman CNC Mill Collets
    By megclay in forum Benchtop Machines
    Last Post: 09-30-2011, 10:15 PM
  2. OKUMA OSP 5000
    By copper in forum Okuma
    Last Post: 07-26-2010, 05:03 PM
  3. Acramatic troubles on a Benchman 5000
    By Owad in forum Benchtop Machines
    Last Post: 10-31-2006, 04:04 AM
  4. Acramatic A2100 Benchman 5000 Prolight ATC
    By jwettroth in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-06-2006, 07:02 AM
  5. Benchman 5000
    By machbuilder in forum Benchtop Machines
    Last Post: 09-01-2006, 01:04 PM
