Hi. Sorry if this question was asked or it's a simple solution. I had 6040 for years but it was stored. Recently I reconnected and having trouble to understand why Z- and Y-axes are reversed. X-axe is fine. If I command up it goes down, same with Y. All motors and wiring same, same controller. The software has default settings, so there is no mirror or other boxes checked. Did I missed anything? I will install another CNC software and see if problem is still there. Anything I can do or check? Thanks.
