544,216 active members*
2,784 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Right-angle milling head
    Sep 2010
    135
    Hello,
    I'm looking to buy a right-angle milling head to use on this horizontal mill. I do have a few questions on how to add tool and program it with Mastercam (fully licensed);
    1 - can I just add the tool in the tool library and go from there like I do with a threading tool (importing model)?
    2 - does the post needs to be modified for this to work?
    3 - if I want to use the tool in 8 different angles, do I need to have 8 different tools or mastercam would offer that option?
    much appreciate in advanced.
    T
    Mar 2008
    602
    Re: Right-angle milling head
    Remember any time you want something new in MC they will find a way to charge you a few thousand dollars. I set up several angled heads and my trick was to use three axis drive curves to so what I needed without any extra multi axis modules, I would created wireframe curves and drive the spindle axis and z axis intersection point as a large cutter and would use 3d curves or trace tool paths.l
    Sep 2010
    135
    Thanks warrenb, I totally understand what you're saying, I prefer to just leave the post alone---been burned in the past.
    I do have to start somewhere and your notes are strong start indeed!
    1 - import tool model at desired angle
    2 - generate code with modified machine definitions. no post modifications needed.
    cheers!!!
  1. angle head on horizontal milling center
    By Egidijauz in forum SIEMENS Sinumerik CNC controls
    Last Post: 08-07-2020, 08:31 AM
  2. Huron head milling machine angle calculator
    By vvraiyani in forum General Other Machine Discussion
    Last Post: 06-21-2020, 09:49 AM
  3. Milling machine, angle head, CAT-40
    By mvoss_chemiflex in forum Want To Buy...Need help!
    Last Post: 08-13-2011, 06:56 AM
  4. Variable angle milling head
    By glsmaverick in forum Haas Mills
    Last Post: 09-02-2010, 05:36 PM
  5. adjustable angle milling head.
    By Beek in forum Cincinnati CNC
    Last Post: 04-27-2010, 05:52 AM
