585,996 active members*
4,575 visitors online*
Results 1 to 1 of 1
    Oct 2021
    Rockey4USB Key not found on Windows XP
    Hi All, I need some help. I am running CNC 16.8 on windows xp and it was working fine but all of a sudden windows got some issues and i had to re install the operating system (Repaird existing OS), since then CNC keeps saying "Key not found, insert usb or in printer port#1 0 at 16". I have tried everything i could do but no luck. USB drivers are installed properly and usb appears as USB key under device manager. Solid green light is on on the USB. please help me with this. I have attached a screenshot of the error too. Error code is: 6043-0-FE53.
  1. Windows key in PP
    By popspipes in forum Tormach PathPilot™
    Last Post: 04-12-2021, 03:05 AM
  2. Windows key in PathPilot
    Last Post: 03-15-2021, 08:47 PM
  3. Problems: Software Driver can be found by windows but can not be installed
    By Melody-gweike in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-24-2013, 12:04 PM
  4. windows 7 and XP network key problems
    By timf in forum EdgeCam
    Last Post: 08-22-2012, 06:18 PM
  5. xml found not found when trying to simulate?
    By Big Chips in forum BobCad-Cam
    Last Post: 06-08-2012, 10:25 AM
