535,179 active members*
3,883 visitors online*
    Jan 2021
    RS-232 cable for M2521 Milticam 3000
    Hi, in our M2521 TCP port failed. I have to use Com-port RS-232.
    I have drawn up a connection scheme and manufactured the cable.
    But Multicam 3000 does not connect to PC.
    ?an you give a scheme of the cable and settings RS-232 for PC?
    Sep 2006
    102
    Re: RS-232 cable for M2521 Milticam 3000
    Not sure about the MC 3000 but the older MC's that used a Serial cable for connection to the computer, and used WinDNC (Win98) or MX32 to transfer files. If i'm not mistaken a DB-9 Null Modem cable is needed..
    Jan 2021
    The problem is solved. I added CTS wire in the cable to the eight pin. I used 'Motion Connection' and 'Job Server' programs.
  1. Need computer cable for Gerber dimension 200 or pinout diagram for cable.
    By Mattster1 in forum Commercial CNC Wood Routers
    Last Post: 09-06-2019, 07:49 AM
  2. Need pinout for Prolight 3000 lathe turret cable
    By DSpeck in forum Benchtop Machines
    Last Post: 05-14-2019, 02:37 AM
  3. Replies: 0
    Last Post: 01-22-2010, 07:06 PM
