592,217 active members*
5,401 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > RTCP setup for 6 Axis machine (table with rotary axis and BC head)
Results 1 to 4 of 4
    Oct 2014
    7
    hello,
    we install a KFLOP motion controller in our 6 axis machine. (rotary A axis on table, BC head)
    All axis motors are working, I can jog in Mach3 and KMotionCNC.
    I have created a Kinematics.txt file and inserted the line 5AxisGimbalBC.
    Now I am stuck. Where do I configure the offset length of the B Axis rotation point?
    May 2006
    4063
    Re: RTCP setup for 6 Axis machine (table with rotary axis and BC head)
    See our wiki on Kinematics and RTCP
    See this section where User kizilkaya explains how to change the PivotToChuckLength.
    You will need to create a new class for 6 axes. If I understand your configuration it might be called TableAGimbalBC.
    HTH
    TK
    http://dynomotion.com
    Oct 2014
    7
    Thank you, that helped a lot, we have RTCP working. At the moment we use the existing 5AxisGimbalCB and just modified the GimbalChuckLength.
    In KMotionCNC we can jog and the center of the spindle stays in position.
    Mach3 does not do that but that is probably a limitation of Mach3. (If we jog in Mach3 there is no RTCP although KMotionCNC shows all axis moving but they don't.)
    In Mach3 we have the tool changer setup and we have a wireless USB pendant to jog and control much of the machine. With a big machine it helps a lot to have a wireless pendant...
    (https://www.cnc3d.com.au/pro-mach3-uccnc-wireless-mpg-pendant)
    We probably have to move to KMotionCNC, are there pendants on the market?
    Thank you !
    Helmut
    May 2006
    4063
    Hi Helmut,
    Correct Mach3 doesn't support Kinematics/RTCP.
    That makes sense. When rotating an axis in Mach3 the Tool Tip moves so KMotionCNC shows this.
    We recommend MPGs wired directly to KFLOP/Kanalog as this guarantees real-time response. See our wiki here. A wired/wireless Gamepad is also supported, see here.
    TK
  1. Setup Mach3 for Sherline Rotary Table 4th axis
    By BOHICAMAN in forum Mach Mill
    Last Post: 05-19-2021, 11:23 PM
  2. Replies: 2
    Last Post: 03-14-2020, 06:06 AM
  3. Replies: 26
    Last Post: 05-24-2014, 03:41 PM
  4. 4th axis/Rotary Table setup. Please help!
    By TheProCreator in forum DIY CNC Router Table Machines
    Last Post: 11-15-2010, 12:11 AM
  5. Rotary Table as 4th Axis (setup help)
    By fc911c in forum Mach Mill
    Last Post: 04-03-2009, 04:08 PM
