591,534 active members*
5,243 visitors online*
IndustryArena Forum > CAM Software > Alphacam > Run Time Error '52'
    Aug 2024
    Run Time Error '52'
    Hi everyone.
    I am a part time AlphaCam user and I only get to use it infrequently. I usually use Catia so I am well versed in Cad but not Alphacam specifically.
    I have opened an existing program that I know works but when I try and output the machine code I get the following error:
    Run-time error '52'
    Bad file name or number.
    It does actually create a machine code file but it won't run on our SCM 3 axis machine.
    If I login using someone else's profile, it all works perfectly.
    Can anyone give me any pointers on what it may be?
    Thanks everyone
    Brian
    Mar 2022
    47
    Re: Run Time Error '52'
    Hi It can be connected with the Windows version 32/64 bit. Can you try select different post and try output code to be sure that it is about the postprocesor for Xilog.
