545,740 active members*
2,075 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Running a probing cycle after a certain amount of parts
    Smile Running a probing cycle after a certain amount of parts
    Running some parts and using the probing system on a haas super mini mill 2 to measure some bores and other geometry. The problem is that it runs the probing cycles every part. Out of 50+ parts not a single one has been out of tolerance, so it measuring for no reason most of the time. I am a bit of a newbie so i do not know how to use control statements and other more advanced stuff. How can i create a program where it runs the probing cycles maybe every 10th part? 25th part? 50th part?
    Sep 2010
    Re: Running a probing cycle after a certain amount of parts
    Block delete would be the simplest solution for you if you have no experience with program logic or macros. Just turn off the block delete when you want to do a measurement
    Aug 2007
    351
    COUNTER 1 for M30 is #3901
    #1=#3901 mod 10
    #2=#3901 mod 25
    #3=#3901 mod 50
    #4=#1+#2+#3
    IF [#4 NE 0] GOTO 1111
    (PROBING)
    N1111
  1. Haas Probing cycle
    By Traceman in forum Haas Mills
    Last Post: 10-30-2020, 06:09 PM
  2. problem with probing cycle
    By Shafidm in forum Questions or Problems
    Last Post: 03-16-2019, 10:48 AM
  3. Short cycle time job, lots of parts - Anyone leave spindle running?
    By 74BurkeMVN in forum Tormach Personal CNC Mill
    Last Post: 09-18-2017, 04:09 PM
  4. CANT GET CITIZEN M20 TO RUN SET AMOUNT OF PARTS
    By MRFRY in forum Swiss Lathes
    Last Post: 04-01-2017, 03:49 PM
  5. Probing cycle ( heidenhain 530 )
    By mrdom in forum General CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-04-2009, 08:18 AM
