585,902 active members*
4,497 visitors online*
    Mar 2009
    36
    Sabre 750 Pendant error
    Hi.
    Can anyone tell me if he encountered this error with Milacron mill pendant and how he solved the problem?
    Thank you
    Attached Thumbnails Attached Thumbnails 20210327_183631.jpg   20210327_184404.jpg
    Mar 2009
    36
    Re: Sabre 750 Pendant error
    Ok... After system load (with pendant fail in Diagnostic) pendant show coords but does not respond.
    Mar 2011
    462
    I have never seen the error message you have on the pendant display, but it clearly is failing the diagnostic test. There isn't much inside the pendant that is field serviceable so it will likely need to be repaired/replaced,
    I have seen many pendants fail after the cable is damaged though, so check to see if there is any evidence the cable has been crushed or cut (that could be causing an open or shorted wire). There is also an extension cable from the DV5 card to the operator's station that could be causing a problem. I can only remember one machine I ran into this though and it was caused by someone working on the machine damaging the connector.
  1. Sabre 750 Acramatic 2100 Error
    By flyinphill in forum Cincinnati CNC
    Last Post: 12-15-2023, 01:30 AM
  2. 94 Sabre 750
    By J-Rod10 in forum Cincinnati CNC
    Last Post: 12-08-2021, 10:50 PM
  3. Replies: 0
    Last Post: 04-01-2018, 04:28 AM
  4. Sabre 750 axis foldback error
    By Slick27 in forum Cincinnati CNC
    Last Post: 05-17-2014, 02:44 AM
  5. Replies: 0
    Last Post: 05-05-2013, 05:40 AM
