589,388 active members*
6,784 visitors online*
Results 1 to 4 of 4
    Jul 2018
    Sanity check shopbot cnc router
    Shopbot sanity check please?
    Is this used old old shopbot worth buying? I believe it is a really old prs alpha. I will be posting on the shopbot forum as well.
    Anyone know how easy a controls update is if the software it has is that unusable? Is it too old to be worthwhile even if it’s really cheap?
    Thanks all
    Attached Thumbnails Attached Thumbnails IMG_6775.jpg   IMG_6776.jpg   IMG_6774.jpg   IMG_6773.jpg
    Dec 2003
    1254
    Re: Sanity check shopbot cnc router
    It sort of depends on what your ambitions are.Unless the machine is worn out and in need of a complete rebuild you ought to be able to produce something with it.With wear and backlash you might not get parts that are as perfect as you might like but they might still be perfectly good enough for a lot of uses and you will produce them more consistently and more quickly than cutting them out with traditional tools.Do you have experience of creating toolpath files or are you starting from scratch?
    If the machine comes with a computer that has been calibrated correctly to run the control software,you could be up and running quite quickly.Without such a leg up you have a few more hurdles to clear in terms of connecting a computer and calibrating it with the control software of your choice or that which users of similar machines might recommend.
    Do you want to make parts or rebuild and improve a machine?There are some projects on this forum which have been running for years with no sign of any parts being made and this implies that tinkering with machines can be an end in itself.Others seem able to locate a machine and after a bit of servicing and checking for wear,get to cutting stuff.With the sheer number of ShopBots out there and working advice ought to be available.
    - - - Updated - - -
    I
    Apr 2004
    5770
    How old? How cheap? Shopbot tools are a cut above the usual aluminum-extrusion routers one generally sees, and they have a large user base. For more specific advice, you might check the forum on the Shopbot site. https://www.talkshopbot.com/forum/forum.php
    Andrew Werby
    Website
  1. Sanity check: CNC mill with DRO.
    By rlaury in forum MetalWork Discussion
    Last Post: 05-17-2021, 02:49 PM
  2. 4x8ft CNC router - steppers, drives and sanity check
    By spiral72 in forum Stepper Motors / Drives
    Last Post: 11-25-2015, 12:03 AM
  3. Need a Sanity Check
    By xTourniquet in forum USA Club House
    Last Post: 08-14-2014, 08:34 AM
  4. Sanity check design please...
    By Rarius in forum DIY CNC Router Table Machines
    Last Post: 03-12-2009, 01:50 PM
