589,390 active members*
6,358 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Sanyo Denki PY2 amp settings for pulse/direction
    Hi, I'm hoping someone here can help me get these amps to work.
    I have three PY2 amps that are currently in an old plasma table. Manual here: https://s3.amazonaws.com/Icarus/DOCU...nuals_2000.pdf
    A new CNC controller is getting put in, so they need to be changed to position control mode so they can accept pulse/direction signals. They were set by default to velocity mode and and encoder is set to "fully closed encoder".
    I've identified 4 changes I need to make:
    Page 7-58 (Mode 4, Page 3) - TYPE control mode - should be set to "Position"
    Page 7-43 (Mode 2, Page 0) - PMOD Position command pulse train form - should be set to 0100-0000
    Page 7-47 (Mode 2, Page 1) - func0 Amplifier function select 0 - should be set to use the motor encoder, not fully closed encoder
    After making these changes and plugging in the CNC controller, Im trying to jog the motor but nothing is happening. I've checked my wiring, continuity and it all looks ok.
    I'm hoping someone who is more knowledgable with these amplifiers, or even someone who can easily see in the manual wha might be missing, could lead me in the right direction. Maybe there's more parameters to change? Maybe more wires to connect to CN1?
    Many thanks
    Quote Originally Posted by derekmccoy View Post
    Many thanks
    Hi, I know this post is old but did you ever get the servo motors going ?
    I’ve just got to the stage where you were at and I’m stuck !
    Regards
    Lyndon
  1. Sanyo Denki CW/CCW Step direction Mode Mach3 question
    By whiteriver in forum Servo Motors / Drives
    Last Post: 11-04-2018, 12:13 AM
  2. Sanyo Denki pulse motor 103-845-1111
    By mufaza in forum Want To Buy...Need help!
    Last Post: 01-05-2015, 09:12 PM
  3. SANYO DENKI BL
    By alpefe in forum Servo Drives
    Last Post: 04-30-2013, 07:00 PM
  4. Sanyo Denki Help
    By Gary D in forum Stepper Motors / Drives
    Last Post: 06-30-2012, 06:10 AM
  5. Sanyo denki P5
    By virgoviggo in forum Servo Motors / Drives
    Last Post: 01-23-2011, 05:37 AM
