592,217 active members*
5,596 visitors online*
Results 1 to 8 of 8
    Jul 2015
    4
    Scoring stained glass
    I am totally uninformed when it comes to CNC but hope this is a simple question. I have a small CNC machine that uses G-Code. I bought it specifically to score parting lines on stained glass. These are the line that you snap or break the excess material away for a project. I have a family friend that understands the coding but can't help with this problem. The cutting head is a roller wheel like you would find on a glass cutter. It's my belief that the rolling wheel will have to be turned to follow the curved lines of our project. There in lies the problem. The machine is fitted with a special head that will accomdate this action. I just need to know how to tell it to turn as it follows the design. Do I have you totally confused? I hope not. I recently saw some diamond tipped etchers but I don't know if they would work for scoring glass. An help will be greatly appreciated. Chuck
    Mar 2003
    35494
    Re: Scoring stained glass
    What control are you using? You need a control that has a tangential mode, with your etcher's rotation handled by a stepper motor.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Apr 2004
    5813
    Either that, or a spring-loaded diamond drag tool like this: Spring Loaded Engraving Tools engrave flat and uneven surfaces
    Andrew Werby
    Website
    Jul 2015
    4
    Thanks for the response. I saw the spring loaded diamond tips but was told they were fine for etching but not for scoring.
    Jul 2015
    4
    The unit came with Mach3 loaded. I am completely uninformed on CNC. My gransons father in law is familiar with G-code and is trying to get up to speed on it. My grandson, bless his heart, is taking a college level G-code introduction course. He's a sharp cookie and will probably be able to handle all our needs but not for a few months. The unit has a seperate motor for the scoring that mounts in place of a router. I'm assuming/hoping this is the stepper motor. Thanks for any assistance you can provide. Chuck
    Apr 2004
    5813
    Often machines like that mount the cutter behind the center of the spindle on a swivel, so that it's dragged along in the right direction. It's not altogether necessary to power the rotation. Look up "drag knife" to see what I'm talking about.
    If this machine was intended for this purpose, and has a motorized swivel, did it come with proprietary software as well?
    Andrew Werby
    Website
    Jul 2015
    4
    The machine has motor that mounts in place of a router and turns the glass scoring blade. The seller provides tech support but right now it wouldn't make sense to me. I am way too much of a novice. I'm hoping to find a place to refer a friend that is CNC savy. The machine is set up with Mach3 which from what I've read here can to the tangential operation. Thanks for the response. Chuck
    Mar 2022
    6
    Your project sounds fascinating! For curved lines, you'd likely need to program the G-code to rotate the cutting wheel as it moves along curves. A 4th axis or specialized software might be required.
  1. Glass scoring cnc wanted.
    By jarrick in forum Want To Buy...Need help!
    Last Post: 01-18-2015, 09:24 PM
  2. stained glass
    By eroltopcular in forum DIY CNC Router Table Machines
    Last Post: 03-09-2014, 05:05 AM
  3. Cutting Stained Glass
    By bisjoe in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2011, 01:44 PM
  4. CNC Glass Scoring Machine Anyone?
    By LHC in forum DIY CNC Router Table Machines
    Last Post: 02-03-2011, 03:44 AM
  5. Breaking glass to a line by scoring it
    By Bob Shaw in forum Videos
    Last Post: 07-09-2010, 02:31 AM
