545,780 active members*
2,266 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Scribing degree graduations on a bevel
Results 1 to 5 of 5
    Jun 2003
    238
    I'm trying to mark graduations on the bevelled edge of a disc? I'm making a degree vernier, how do I go about getting the lines on the bevel at the correct angle, the disc has a 60° bevel about .4 wide. The numbers would be good too but not essential.
    Jun 2003
    238
    Re: Scribing degree graduations on a bevel
    Ok, I figured out that I can project curves, the numbers have to be vectorized, but how do I then get rid of the original lines without deleting the lines on the part?
    Jun 2003
    238
    Just takes time.Oddly the lines were projected to both sides of the disc so I manually editing out the original lines and text as well as the undesired parts and then used 3D engrave to generate the gcode. Is there a way tohave the engraving projected to only the first surface?
    Jun 2008
    1837
    Quote Originally Posted by L98FIERO View Post
    Yes, you can do that by going to "Utilities" then select "Stitching" and the select "Unstitch Solids to Surfaces" or "Unstitch Surface from Solid", once you have done that you can create a new Layer for the Bevel Face, that way you can toggle it on/off as required.
    You can then create a new Layer for the original numbering so they can be toggled on/off as required, or, you can just go to front view, box select all the original numbering in one go and delete them if you don`t need them again, plenty options
    Image of the Simulation of my little example below. Be nice with a 4th axis. FYI Done in V28
    Jun 2003
    238
    Thank you, that's much more simple than deleting the offending parts!
  1. High Speed Scribing
    By Jake26 in forum CNC Tooling
    Last Post: 01-21-2015, 07:00 PM
  2. Replies: 9
    Last Post: 06-05-2014, 04:41 AM
  3. Mini Boring Head for Taig Mill (lead screw graduations)
    By slashr76 in forum Taig Mills / Lathes
    Last Post: 08-29-2010, 08:27 AM
  4. Replies: 3
    Last Post: 06-30-2008, 01:30 AM
  5. 45 degree bevel on angle iron
    By Rypper in forum DIY CNC Router Table Machines
    Last Post: 11-14-2006, 07:00 AM
