525,667 active members*
2,344 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Servo motor biased in one direction
    Hi, hope someone that kows about servo motors can help. I have a Sanyo Denki PY2 drive and a P3 motor set to position mode. I have plugged it in and I can get it to jog quite nicely using the drive's handheld remote. I believe it uses velocity mode to jog. However, when I plug it into my controller (Masso G3 which is a Step/Dir unit) and tell it to move CCW, it keeps spinning after the move finishes. When I give it a CW move, it does the move pretty well (a bit of jerking afterwards). Also, I can easily turn the shaft CCW but it fights me when I try to turn it CW. As you can see in the video below, It reacts to me barely touching the shaft. Any help is appreciated.
    https://streamable.com/5nmxdg
    Dec 2012
    183
    Re: Servo motor biased in one direction
    Hello.
    I recently had a similar problem. It was a rusted connector on the drive. I replaced the female connector and cleaned the male connector on the drive using flux (the one used to clean copper clads in electronics servicing) rubbing it with a cotton swab.
    Isopropyl alcohol is the recommended procedure but I have found that flux gives better results.
    I hope this helps.
    Regards.
    I think you might be right. Moving the encoder connector does affect the behavioour. Although the pins on both female and male look good. Could be bad solders on the drive connector. I will try to clean it as you said and see what happens. Failing that, I'll open the drive and check the solder joints.
    Muchas gracias desde el Reino Unido, originalmente de Yucatan.
  1. Replies: 8
    Last Post: 06-27-2019, 04:49 AM
  2. Servo will only move in one direction
    By dracozny in forum Servo Motors / Drives
    Last Post: 09-28-2014, 09:07 PM
  3. PWM/direction servo
    By punisher454 in forum Dynomotion/Kflop/Kanalog
    Last Post: 10-23-2012, 04:49 PM
  4. servo motors will not jog two direction
    By thunderbite in forum DIY CNC Router Table Machines
    Last Post: 08-06-2009, 09:07 PM
  5. How To Change Direction on DC Servo?
    By parametric.ms in forum Servo Motors / Drives
    Last Post: 09-16-2008, 05:10 AM
