540,760 active members*
7,072 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Servo motor vipration and not stable
Results 1 to 12 of 12
    Jan 2020
    23
    Machine Colchester1100
    Fanuc
    Machine reafrance and not give any error
    But the x axis after stop reafrance
    Give me vipration and not stable . It try to move left and right and not stable
    I change the servo implifire but still same error
    I clean the encoder .clean the liner roller
    Change the encoder cabl
    Its same error
    Please help
    Re: Servo motor vipration and not stable
    Quote Originally Posted by Yasser2000 View Post
    Fanuc
    Its same error
    Please help
    You can check motor grounding or the parameter setting on the driver.
    Jan 2020
    23
    Grounding is ok
    Wich parameter
    Can you tell me please
    Jan 2020
    23
    I change parameter 1825 . Its x motor gain loop change it from 3000 to 2000
    The vipration is small down . But still same problem
    The 3 coil of motor is ok by ohm
    Do you think motor problem
    Please help
    Jan 2020
    23
    Please help
    Dec 2009
    669
    look for Load Inertia paramenter LDNIT and try to decrease the value
    Jan 2020
    23
    Quote Originally Posted by zavateandu View Post
    I try but its same problem
    Apr 2015
    169
    Check for worn ball screw or bearings, backlash can cause servo motor to hunt or vibrate.
    Jan 2020
    23
    Quote Originally Posted by Bdrangdo View Post
    We allready find the 2 bearings of ball screw up side
    Is damage. And then motor become over heat and over loud
    Then we change that 2 bearings
    But motor still same problem
    Vibrating and not stable. After stop . It try to move small movie left and right
    Please advise
    Jan 2020
    23
    What do you mean with . Backlash
    Jan 2020
    23
    Please help
    Apr 2015
    169
    Please help
    Backlash is term used to describe excessive clearances caused by worn bearings or ball screws and nuts. When the backlash becomes too great it can cause the servo to vibrate and shake. You can easily feel this by turning it by hand. Also you said the motor had heated up, check to see if the windings have not shorted.
  1. Replies: 3
    Last Post: 02-11-2015, 06:07 AM
  2. Stepper Motor isn't stable
    By kure6592 in forum Dynomotion/Kflop/Kanalog
    Last Post: 11-07-2014, 07:54 PM
  3. Replies: 0
    Last Post: 10-21-2014, 09:29 PM
  4. Axis servo motor vs. Spindle servo motor
    By iyerks in forum Servo Motors / Drives
    Last Post: 09-25-2012, 04:58 PM
