535,443 active members*
2,954 visitors online*
    Oct 2008
    1530
    Servo Wiring Harness TL-1/2
    On a 2005 TL-1, the Servo wires come in on the Left side of the electrical panel.
    On mine, there is a large square plastic fitting that attaches to the harness, then goes into the side of the enclosure. A bulkhead fitting.
    I have some cracked of flex conduit I wanted to replace. I know the two connectors going to the servo and encoder are molded on so wouldn't be able to slide that flex conduit off that end, however does anyone know if the other end comes off (the bulkhead fitting at the enclosure end)?
    Richard
    Oct 2008
    1530
    Re: Servo Wiring Harness TL-1/2
    I drove to the shop and removed the bulkhead fitting and it is a molded item. I hate to use it, but split loom will need to be used.
  1. Replies: 1
    Last Post: 09-11-2018, 11:49 AM
  2. wiring check please. parallel wiring to maximum current to servo motors
    By Novett in forum General CNC Machine Related Electronics
    Last Post: 10-11-2014, 07:54 PM
  3. WIREING HARNESS
    By AB PRODUCTS 1 in forum Haas Mills
    Last Post: 09-30-2010, 07:29 PM
  4. WIRERING HARNESS
    By AB PRODUCTS 1 in forum Fanuc
    Last Post: 09-30-2010, 11:39 AM
