584,874 active members*
5,120 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > Setting work offset on irregular parts
    Jan 2021
    6
    I have a job coming up where the part is larger than the XY travel on my table, so I’m planning on doing the part in a few ops.
    The issue I have is the part has no straight edges to pick up with an edge finder. It’s basically an irregular doughnut shape, however there a lots of bored holes I can locate, however I would need to locate multiple holes to get accurate rotation of the part.
    My question is there a way in fusion 360 to probe multiple bores to set a work offset?
    I hope this makes sense, cheers
    Dec 2013
    5717
    Re: Setting work offset on irregular parts
    You only want to use one hole as the reference for each setup. But dial in two holes to get the rotation correct. The way I do this is to move the machine to the 0,0 location then locate the reference hole and clamp the part down near that hole, then move the machine to the second hole location, and move the part to zero out that location the expected coordinates. A coaxial indicator would work well for this.
    Jim Dawson
    Sandy, Oregon, USA
    Jan 2021
    6
    That’s simple, I’ll give it a go.
    Hopefully I can hit the tolerances
  1. Work holding irregular parts.
    By Spinnetti in forum Work Fixtures / Hold-Down Solutions
    Last Post: 01-22-2013, 07:20 PM
  2. Setting my Z work offset
    By Jaynboom in forum Tormach Personal CNC Mill
    Last Post: 02-02-2012, 06:14 PM
  3. Help setting work shift offset in LX3 ?
    By panaceabea in forum Hyundai Kia
    Last Post: 05-29-2011, 03:51 PM
  4. G10 Work Offset Setting?
    By Wheelz in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-10-2010, 12:47 AM
  5. setting work offset(G54 etc)
    By dek in forum RFQ Feedback
    Last Post: 04-07-2010, 03:17 AM
