587,006 active members*
3,009 visitors online*
Results 1 to 15 of 15
    Dec 2012
    Shaking Problem On My Laser Machine
    Hello
    I just bought this Laser/Engraving Machine
    I used 2 days and everything was perfect
    Today when it was cutting it started to shake when the Y axis try to move.
    Its not moving at all.
    here is the problem in the video on the link
    http://img20.imageshack.us/img20/981...lonhwpcydv.mp4
    please help me
    Oct 2011
    155
    Belt too tight or too loose?
    IIRC, it should only move up and down 10-20mm.
    Dec 2012
    belt is little bit loose but machine arrived like this to me.I mean for 2 days it was working in this situation thats why Im not sure about belt.
    Im suspicious about drivers but Im not sure
    Can't tell much from the video but my best guess would be the belts jumping teeth, if not then I'd suspect a driver card. If possible switch the X & Y driver cards round to test if the same problem occurs. If it swaps from X to Y then its likely a card or a stepper, if it doesn't then it's the belt jumping.
    Tension looks ok, flatbeds do tend to have a bit more slack due to the length of the belt but my second best guess would be a physical blockage jamming the gantry causing the belt to jump.
    best wishes
    Dave
    On second look, i'd look at the gantry angle, if the belt has jumped then it will be trying to pull the gantry along at a crab angle.
    best wishes
    Dave
    Dec 2012
    Quote Originally Posted by Exsecratio View Post
    best wishes
    Dave
    Hello Dave
    I very glad about your message. Im thinking about the driver problem because when I tried to move the x and y axis with my hand without turn on the machine it works ok to backward to forward but when I try to do the same process with the arrows on the panel Y axis start to shake and do go anywhere . I guess some of the cables plug out from its of place or completly Y axis driver has a problem tomorrow I will check out the cables on the Driver
    Jul 2008
    390
    What type of motors are being used? Steppers or servos?
    Dec 2012
    Quote Originally Posted by amishx64 View Post
    its steppers
    Dec 2012
    day 2 still I couldnt solve the problem.
    I check the cables on step motor driver the cable seem ok and the green light is on I couldnt solve the problem
    Apr 2006
    251
    Normally if one wire it not connected properly to a stepper the stepper will judder instead of run. Take the belt off and check if the stepper moved smoothly then try to load it up a bit using your fingers.
    Dec 2012
    Quote Originally Posted by epilotdk View Post
    i can easily move Y axis with my finger manually but when i try to make it with control panel it gets mad start to shake and go forward and backward it seem like it takes forward signal then immediatly backward signal
    Jul 2008
    390
    I was going to say the exact same thing. Do a continuity test from motor to control board and then a resistance test across the individual leads to each coil while disconnected from the driver.
    Nov 2009
    115
    belt shaking problem
    belt shaking problem may have two reason
    one is stepper motor
    the other problem may because of the motor basement
    so whats material of your motor basement? platic or how many mm thickness metal material?
    tina from gweike laser
    email: [email protected]
    MSN: [email protected]
    SKYPE: lysunshine521
    Dec 2012
    I solved the problem.The problem was from the cable of the Y axis I changed it and everything was solved.
    Thank you all for your support
    Apr 2024
    Re: Shaking Problem On My Laser Machine
    My laser machine also start shaking, finally I get a workaround.
    Before switch on laser machine, connect laptop/pc first. Open the cutting tool application (set it to last working configurations)
    Then switch-on the laser machine.
    As soon as we switch-on laser machine it expect some initial commands and if laptop is not connected, machine will not receive initial commands and start misbehaving or shaking.
    Also let me know if this work for others.
  1. Problem with my laser engraving cutting machine JZDQ-9060E type
    By almamy in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-16-2013, 04:37 AM
  2. Optiray Laser marking 150W machine problem
    By mecanicu in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-17-2012, 07:10 PM
  3. Replies: 0
    Last Post: 05-17-2012, 02:29 AM
  4. Has anyone experienced the Shaking?
    By Field Worker in forum Excitech routers
    Last Post: 01-25-2009, 06:59 PM
