591,376 active members*
6,516 visitors online*
    Apr 2003
    96
    Sheet metal feature
    Hello all, I have a part and I’m not for sure what to call out for a hole feature. I don’t know if it would be a flanged hole or not. See attached pictures. If anyone can tell me what it is I really appreciate it. If you know of a video or website showing how to make these holes that would be great also.
    Would these holes be punched before it is formed?
    I hope the attachments uploaded.
    Thanks for any help,
    Eric
    Dec 2003
    1267
    Re: Sheet metal feature
    Over here it might be described as a hole with a swaged edge and you would normally create the aperture first and then apply the swaging tool to form the edge.You might have to make the swaging tool to the profile you are seeking.The ring around the edge in IMG_6950 shows the diameter of the hole in the larger half of the tool impressed in the surface of the material and the depression around the edge in IMG_0952 shows that too much force was used and it has created a hard spot.
  1. Sunmise-plastic molding, metal casting&machining,sheet metal fabrication,
    By SUNMISE in forum Manufacture Company Listing
    Last Post: 05-08-2021, 08:27 AM
  2. Replies: 0
    Last Post: 12-26-2020, 04:46 AM
  3. Best Feature of Portable Metal Cutting Machine
    By Steel Tailor in forum South Africa Club House
    Last Post: 01-07-2015, 03:47 AM
  4. Metal laser cutting machine is easier to achieve diversification sheet metal
    By mornlaser2014 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-16-2014, 07:46 AM
  5. Replies: 6
    Last Post: 10-05-2013, 03:40 AM
