585,973 active members*
4,175 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Sherline 5400 / labvolt 5400 mach3 wiring
Results 1 to 6 of 6
    Jul 2017
    348
    Hi
    I have a labvolt 5400 (sherline 5400)
    Im trying to retrofit by simply using a cheap mach3 bob and using existing electronics
    The labvolt has a dpindle control board...Does anyone know the process to connect spindle control board to to mach3 bob?
    Jul 2017
    348
    Re: Sherline 5400 / labvolt 5400 mach3 wiring
    i was able to figure out the stepper motor wiring and i got mach3 to jog all 3 axis so im off to a good start but
    im not sure how to wire up the labvolt spindle
    hope someone can help
    Jul 2017
    348
    Hi
    I obtained a schematic for the stock spindle speed controllerand per schemstic a 5k potentiometer can be connected to p1 p2 p3 to control spindle
    I will try this.
    Jul 2017
    348
    i was able to figure out myself
    Jun 2015
    64
    Any tips and tricks? I'm getting ready to take a look at this, just picked up one at an auction.
    Jul 2017
    348
    Hi
    Assuming ur labvolt functions ok...i bypassed the pc board inside and used a cheap mach3 breakout board
    I kept all other electronics
    There are lots of ways to retrofit...after 2 yrars of tinkering and once i found out it was very difficult and costly to find the orig proprietary software and retrofit it.
  1. Labvolt 5400 5500 5600 update firmware procedure????
    By Shelby5041 in forum Benchtop Machines
    Last Post: 01-10-2020, 03:26 PM
  2. Yet Another LabVolt 5300 Lathe (Plus a 5400 Mill)
    By jbaz in forum Benchtop Machines
    Last Post: 02-13-2016, 02:02 AM
  3. Sherline 5400 or 2000
    By Rift in forum Benchtop Machines
    Last Post: 04-21-2010, 09:28 PM
  4. sherline 5400
    By Speedygonzales in forum Benchtop Machines
    Last Post: 01-09-2010, 06:35 PM
  5. Sherline 5400, X2, or Taig?
    By tipschips in forum Taig Mills / Lathes
    Last Post: 08-02-2006, 02:25 AM
