585,556 active members*
3,456 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > Sherline Lathe Modifications - feedback / experience
Results 1 to 5 of 5
    Jul 2013
    84
    Dear Forum Members,
    I am seeking feedback / information on the following mod idea for may CNC lathe.
    Scenario:
    I wish to use automatic sensing for cnc mach3 control. I can auto-centre with an isolated rob but i would like to make this part of the overall setup.
    thoughts:
    isolate drive unit and tailstock from base with non-compressible/non-conductive material (thin sheet) and through this isolation the cutting tool when connecting touching material with act as a sensor.
    any thoughts...?
    Thx
    Feb 2007
    711
    Re: Sherline Lathe Modifications - feedback / experience
    wouldn't it be easier to isolate only the toolpost?
    Another idea is to have a touch probe mounted on the toolholder and figure out the offsets between that and the tools.
    Nov 2009
    4415
    Both could be done and why not?
    A lazy man does it twice.
    Sep 2006
    509
    A potential problem with this idea is that a piece of swarf gets between your tool and the stock you are sensing, giving you a false offset to your work.Keeping the tool clean during sensing moves becomes a factor and adds complication.
    Jul 2013
    84
    yes i hear you on this , perhaps a base plastic coating would reduce risk but yes i need to watch this
  1. New CNC Lathe Build (Need Design Feedback)
    By dwschool in forum Vertical Mill, Lathe Project Log
    Last Post: 04-23-2013, 06:58 PM
  2. Manual Machinist with Lathe experience - IL
    By MachiningJobs in forum Employment Opportunity
    Last Post: 04-04-2011, 11:09 PM
  3. Feedback on SNK Prodigy Lathe
    By philipslack in forum Uncategorised MetalWorking Machines
    Last Post: 12-28-2007, 02:02 AM
  4. Daewoo Lathe feedback
    By Gunner in forum Daewoo/Doosan
    Last Post: 07-26-2005, 09:08 PM
  5. Feedback on an Emco ET-420 CNC Lathe
    By Gunner in forum Uncategorised MetalWorking Machines
    Last Post: 02-03-2004, 10:22 PM
