585,906 active members*
3,563 visitors online*
IndustryArena Forum > MetalWorking Machines > Shopmaster/Shoptask
IndustryArena Forum: Shopmaster/Shoptask
Page 11 of 30 91011121321
Threads 201 to 220 of 599
Discuss Shopmaster/Shoptask machinery here!
  1. Running VFD under Mach3
    Started by jlmccuan, 09-04-2014 11:57 PM
    art, changed, command, fine, frequency, ideas, mach, mach3, manually, motor, parameters, run, running, send, set, set up, shows, stabilizing, star, start, trouble, vfd
    09-13-2014, 07:05 PM Go to last post
  2. Air jets added under quill.
    Started by julian wilson, 09-04-2014 03:41 PM
    adjust, air, art, bolts, bridge, cad, control, copper, cut, cutting, fluid, machine, mist, post, power, power supply, pump, quill, slot, star, supply, switch, tool, welding
    09-10-2014, 10:19 PM Go to last post
  3. QCTP on the Shoptask
    Started by Tom488, 09-01-2014 04:42 PM
    09-04-2014, 08:12 PM Go to last post
  4. Shoptask 1720 gold three phase conversion
    Started by tgorsuch, 08-10-2014 03:16 AM
    170, conversion, fm50, gold, motors, mounting, order, ordering, phase, plan, planning, purchase, ready, rpm, shaft, shop, shoptask, spec, teco, thoughts, three phase, version
    09-04-2014, 12:44 PM Go to last post
  5. Fix for Patriot leaking spindle seal
    Started by Tom488, 08-12-2014 08:25 AM
    08-30-2014, 01:46 PM Go to last post
  6. Patriot PDF's
    Started by jlmccuan, 08-22-2014 09:53 PM
    ces, cnc, cnc machines, control, couple, differences, documentation, functions, how much, level, machine, machines, patriot, pdf, pdfs, send, serial, set, set up, spindle, spindle control, vfd
    08-29-2014, 07:10 PM Go to last post
  7. Increase Mill Spindle to Support Column Clearance
    Started by jlmccuan, 08-19-2014 02:54 AM
    block, bought, bridge, clearance, cnc, column, crease, half, increase, make, mill, part, patriot, pictures, spindle, support, surface, table, vfd, week, wires, work
    08-21-2014, 01:13 AM Go to last post
  8. Making some nice things on my Patriot.
    Started by julian wilson, 08-04-2014 02:17 PM
    151, 622, adjust, art, assembly, box, cycle, fuel, fuel injection, ice, injection, machine, machining, made, milling, motor, nice, posting, replacement, sheet, star, steel, tech, tool, tramming
    08-04-2014, 03:31 PM Go to last post
  9. Shopmaster VFD Homing issues.
    Started by usalfa, 06-25-2014 10:54 PM
    06-25-2014, 10:54 PM Go to last post
  10. Setting up WJ200 VFD w/ Shopmaster .
    Started by countryguy, 05-08-2014 07:00 PM
    application, automation, code, cost, data, environment, erp, gage, head, logging, machining, offer, pci, product, resource, review, ring, script, services, special, string, student, vfd, website, wj200 vfd forward reverse
    05-24-2014, 03:34 PM Go to last post
  11. Issues with Shopmaster owners
    Started by TeaManMachine, 01-25-2012 12:40 AM
    4 Pages
    1 2 3 4
    05-18-2014, 05:16 AM Go to last post
  12. A Remedy for table twist
    Started by wormwood, 08-29-2013 07:47 PM
    rough
    05-04-2014, 08:24 PM Go to last post
    05-01-2014, 06:17 AM Go to last post
  13. Mach 3 has some CAM Wizard and CAM add-on packs
    Started by countryguy, 04-30-2014 03:00 AM
    ..., cam, dolphin, easy, feedback, general, hobby, long, mach, mach 3, mach3, mill, needed, offer, posting, project, questions, review, screen, setup, software, star, time, wizard, work
    04-30-2014, 03:00 AM Go to last post
  14. Shopmaster Patriot VFD Owners, Your Thoughts?
    Started by jbaz, 04-22-2014 09:17 AM
    04-25-2014, 09:14 AM Go to last post
  15. Optical Lathe RPM Opto equiv
    Started by countryguy, 04-23-2014 07:05 PM
    163, 167, belt, buy, chuck, combo, lathe, lathe chuck, mach, mach 3, mill, optical, output, patriot, product, retention, rpm, sensor, series, setup, transistor, update, wanted, wheel, wires
    04-23-2014, 08:37 PM Go to last post
    04-21-2014, 07:54 PM Go to last post
  16. Trumph 3030 L20
    Started by SJ74, 04-21-2014 07:49 PM
    buying, convert, directory, drivers, dxf, issues, laser, lasers, limits, load, lst, nes, nesting, nesting software, operator, operators, parts, post, short, site, software, tech, touch, trumpf, work
    04-21-2014, 07:49 PM Go to last post
  17. Mill Table Drive
    Started by dogboy, 02-02-2014 03:45 PM
    02-10-2014, 01:53 AM Go to last post
    01-29-2014, 08:54 AM Go to last post
Forum Information and Options
Users Browsing this Forum
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
