585,604 active members*
3,342 visitors online*
IndustryArena Forum > MetalWorking Machines > Shopmaster/Shoptask
IndustryArena Forum: Shopmaster/Shoptask
Page 2 of 30 123412
Threads 21 to 40 of 599
Discuss Shopmaster/Shoptask machinery here!
  1. Lathe ER-40 collet chuck for Shoptask
    Started by arielnh56, 08-25-2021 12:35 AM
    chuck, diameter, fit, listing, spindle
    10-02-2021, 10:47 PM Go to last post
  2. Lathe spindle encoder drive
    Started by arielnh56, 09-13-2021 05:57 PM
    09-28-2021, 06:29 PM Go to last post
  3. Nema23 425oz/in steppers for 1720 XMTC?
    Started by arielnh56, 12-12-2019 02:18 AM
    cnc, machine, motors, nema23, original
    09-28-2021, 02:55 AM Go to last post
  4. 2018 Mill Turn Configuration for Fusion 360
    Started by jdub63, 08-17-2021 10:04 PM
    configuration, fusion, mill, separate, set
    08-18-2021, 04:49 PM Go to last post
  5. Probe it
    Started by tmatt44, 03-19-2021 03:02 AM
    cnc, mill, probe, recognize, turn
    03-20-2021, 04:40 AM Go to last post
    03-10-2021, 11:19 PM Go to last post
    03-10-2021, 12:37 AM Go to last post
  6. For Sale Mill Turn
    Started by coop8va, 01-25-2021 09:30 PM
    02-14-2021, 05:21 AM Go to last post
  7. CUSTOMER MODS ON MILL TURN BENCH
    Started by JTJT, 01-23-2017 11:31 PM
    01-30-2021, 09:02 AM Go to last post
  8. Power Draw Bar build
    Started by mccafferty, 01-16-2021 03:37 AM
    01-29-2021, 08:18 PM Go to last post
  9. Preload on spindle shafts
    Started by mccafferty, 12-10-2020 04:22 PM
    mill, preload, shafts, sleeve, spindle
    12-10-2020, 04:22 PM Go to last post
  10. New To ShopTask or ShopMaster
    Started by Pjblues1, 05-22-2017 04:02 PM
    2 Pages
    1 2
    cnc, hobby, machinist, mill, work
    10-24-2020, 06:23 PM Go to last post
  11. collete upgrade to shoptask 1720
    Started by minsk, 05-03-2020 05:15 PM
    06-19-2020, 02:28 AM Go to last post
  12. Z-axis DRO mount
    Started by arielnh56, 06-19-2020 02:18 AM
    ring, loctite, z-axis, screws, set
    06-19-2020, 02:18 AM Go to last post
  13. Relays
    Started by tmatt44, 05-20-2020 05:49 AM
    air, external, power, solenoid, supply
    06-02-2020, 02:15 PM Go to last post
  14. V8 Inverter Error Code 10
    Started by NDBoyd, 05-23-2020 06:51 PM
    control, error, lathe, spindle, turn
    06-02-2020, 02:12 PM Go to last post
  15. Configuration files for a Millturn and Darwin
    Started by NDBoyd, 03-06-2020 11:59 PM
    configuration, darwin, mach, mach4, millturn
    05-08-2020, 08:52 PM Go to last post
  16. Mill Turn 5C chuck
    Started by jdub63, 12-07-2019 04:45 PM
    02-25-2020, 06:40 AM Go to last post
  17. Hello! 1994 Shoptask XMTC - modded
    Started by SupraRich, 12-30-2018 12:14 AM
    cnc, shoptask, spindle, tormach, vfd
    12-25-2019, 02:43 AM Go to last post
  18. Squaring my Y axis to the X axis
    Started by Tonkabot, 10-25-2018 09:20 PM
    degrees, pivot, point, spindle, square
    12-11-2019, 06:06 PM Go to last post
Page 2 of 30 123412
Forum Information and Options
Users Browsing this Forum
There are currently 2 users browsing this forum. (0 members & 2 guests)
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
