589,388 active members*
6,890 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > shottky diodes on original heiz controller
    I have a old Heiz Zero-1 axis controller and need to replace the shottky diodes on 1 axis.
    The marking on the diodes is T6 FE 2D which has not help me find the exact part I need and the dimensions are 3mm in diameter and 6.5 mm in length.
    Could anyone give me information so I can order the right part.
    I have some 1N5822 3A 40 V which are too big to fit in the existing holes but I believe would do the job if I filed the legs thin enough.
    Jun 2005
    1733
    Re: shottky diodes on original heiz controller
    Go to digikey.com and search for a doodle with the markings u found there site is very good at these codes
  1. Soldering diodes
    By NetStorm in forum Stepper Motors / Drives
    Last Post: 10-27-2013, 09:52 PM
  2. SLA7026 diodes ?!?
    By ifsercon in forum Stepper Motors / Drives
    Last Post: 04-13-2011, 03:03 PM
  3. Eliminating original controller card
    By C.Wilson in forum Controller & Computer Solutions
    Last Post: 01-29-2009, 10:00 PM
  4. Questions on the original UHU controller
    By southernexplore in forum UHU Servo Controllers
    Last Post: 08-16-2008, 06:52 PM
