524,268 active members*
2,763 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Open Source Controller Boards > Open source low cost servomotor controller
Page 2 of 8 1234
Results 21 to 40 of 141
  1. #21
    Registered
    May 2016
    41
    Re: Open source low cost servomotor controller
    Quote Originally Posted by Andreiir View Post
    There is a way to put a encoder in this config , or i don't see one .
    Thanks .
    Yeah, the encoders plug into the top right part of the board.
  2. #22
    Registered
    Jul 2016
    Sorry to dig up an old thread here, but whats the progress here?
    I am doing some research around safety with CNC machines, and this interests me because it seems it would have the capability to detect when it has hit a foreign object, potentially allowing it to stop if it hits an errant hand before crushing it. Obviously this will only work for machines which have a fairly predictable load/friction, but considering most fingers can withstand 500N briefly before suffering permanent damage, and most CNC machines don't use anywhere near that much feed force, we might be able to design a machine which won't cut your fingers off accidentally.
  3. #23
    Registered
    May 2016
    41
    Quote Originally Posted by JustPassing View Post
    Yes, this should be quite straightforward with ODrive. I already plan to do automatic machine mass/friction identification, and to use model based feed-forward for most of the control action. So it should be possible to look at the tracking error to identify if there are any major disturbance forces, and hence take action.
    The ABB YuMi robot, that I was working on a few years ago, has a similar feature.
  4. #24
    Registered
    1939
    I am very interested in this project. I have seen your videos and they are pretty impressive. I can see how it already could be applied to smaller machines such as 3D printers and small routers. I have a benchtop milling machine and was wondering if you have tried this on larger machines. Also, does this take step direction signals like a typical stepper motor driver, or some other method.
  5. #25
    Registered
    May 2016
    41
    Quote Originally Posted by 109jb View Post
    Thanks!
    On the third video on the project page, you can see a demo with a 3kg mass moving 80cm.
    Yeah, step/direction input will be, by popular request, the the first available interface to control ODrive.
  6. #26
    Registered
    1939
    Quote Originally Posted by macdowswe View Post
    Thanks!
    Well yes, I saw that video. However, I am wondering if it has been tried on a larger machine. A 3 kg mass on linear rails is still really nothing compared to what I am talking about. I'm considering trying it on my milling machine so I am talking more like a 40-50 pound mass moving vertically at at least 200 inches per minute. It is driven by a ball screw, but rides on dovetail slides which will have considerable more friction that linear rails. Has anyone attempted anything like this?
  7. #27
    Registered
    May 2016
    41
    Ah fair enough. No, I haven't done anything like that. I don't think it will be a big issue though, as long as the gearing is well dimensioned.
    Get a board, and try it ;D
  8. #28
    Member
    Jun 2010
    3997
    I do not share your optimism. If all you are running are 2 mm cutters into timber, that's fine. But try running a 2" face mill across steel and see what forces are involved. Or try running a 1/2" drill into steel.
    There is a reason why larger machines have larger motors - and safety doors.
    Cheers
    Roger
  9. #29
    Registered
    May 2016
    41
    Quote Originally Posted by RCaffin View Post
    Cheers
    Roger
    Yes, I agree with you. The method I outlined will only work if your fault force is much higher than any unmodeled disturbance force that occurs during normal operation. For some machines and applications, that is the case, and for some it won't be.
    Cheers
  10. #30
    Registered
    1939
    Are boards available and if so, where and how much do they cost?
  11. #31
    Registered
    May 2016
    41
    I will be facilitating a couple of production runs at different stages of maturity of the project. I expect that the early prototypes will be around $100, and with a larger run later on will be closer to $50. You can check out the details, and sign up for a board at any stage, here: https://hackaday.io/project/11583-od...nd-development
  12. #32
    Registered
    May 2016
    41
    The time has finally come for the manufacturing run of ODrive v3.1. They are now on the way, and should arrive early to mid January.
    At this stage, around 20 board kits are going out the people who signed up to the "Inital development" phase. They have not been all allocated yet, you can signup here.
    Since the boars are going out to just a small group of early developers, I will have the time to personally get you up to speed with the codebase and help to get going with the hardware. Then, together, we can prepare some stuff that is a bit more stable and a bit more documented for when the alpha testing begins.
    The cost for me to get this small batch of boards manufactured was $96 per board, so that is the amount I need to ask for a kit, plus shipping.
    The kit involves basically everything seen in the above picture, and consists of:
    • ODrive v3.1
    • USB Programmer
    • A set of the optional large gauge wire screw terminals
    • A set of pin headers
    • Some nylon standoffs
    I hope that ODrive will be able to help you make an awesome robotics project, thank you so much for your contribution to helping people have access to open robotics hardware and software.
  13. #33
    Registered
    Jul 2012
    106
    Is it just me or is $96.00 for a kit a little pricey based on what is provided?
    It's a shame eagle files aren't available, I'm almost certain my friend could have this board made and populated for $50.00 or less each in a small quantity like 50pcs.
  14. #34
    Registered
    May 2016
    41
    Quote Originally Posted by websrvr View Post
    The design is available on GitHub, CircuitMaker, and CircuitHub. Please let me know where you looked and failed to find the links, and I will put the links there.
    The price is quite high, I agree. This is because I used a turnkey professional manufacturer, CircuitHub, and only did a run of 28 boards. If your friend can have the boards made for less, that would be fantastic for the project.
    Please let me know if you, or your friend, would be willing to help with that.
    Cheers,
    Oskar
  15. #35
    Registered
    Jul 2012
    106
    Cheers,
    Oskar
    I guess you didn't understand what I was saying.
    Your schematic and PCB layout file are not usable by my friend, he only works with eagle files and wont waste time trying to convert the ones you have.
    He has a preference for Version 6.3.0 but can accept Version 7.x if you have a licensed copy to generate unrestricted files.
    If you need a licensed version of eagle so you don't have any board restrictions, this can possibly be arranged.
    What this means is if you can't give me the schematic and PCB layout files in eagle format i wont be able to have my friend make the boards but he did estimate cost to be around $46.00 each (based on parts and board size) for a quantity of 50pcs and less on larger quantities.
  16. #36
    Member
    Jun 2010
    3997
    Tough.
    The world will not dance to your tune. The plans are FREE, for heavens sake!
    Cheers
    Roger
  17. #37
    Registered
    Jul 2012
    106
    Tough.
    Cheers
    Roger
    It never ceases to amaze me that someone says something which clearly indicates they didn't think before they responded or lack the faculty to see value in an offer.
    RCaffin, why would you inject this nonsense?
    Are you really that clued out that you can't understand the benefit provided by my friends offer if the files are in eagle format?
    Since you seem pretty clueless I'll clarify it for you, no eagle files and my friend wont produce the boards inexpensively, you don't have to be a rocket scientist to understand this, just have some common sense and the ability to read.
    Since it is doubtful you will make an offer to produce the board at a reasonable cost I fail to see how interest will be maintained for a product that is not reasonably priced when there are full and complete retail solutions at a fraction of the current cost.
    For $62.00/pc I can buy a 6.5A/80V (AC 20V-80V / DC 20V-150V) stepper driver including the heatsink with an MOQ 10pcs and since the current cost is so high for an incomplete solution it wont help it survive past the OP's personal project and even he realizes this.
    So, you are saying people should buy the product despite it's inflated costs just because you think they should, yeah right, good luck with that logic.
    In closing, I would like to thank you RCaffin for informing me that the project doesn't need any help to produce the boards at a reasonable price and that it can live with the over/double priced product which doesn't make it an affordable or reasonably priced solution which in turn contributes to it's demise.
  18. #38
    Member
    Jun 2010
    3997
    Not wrong planet - wrong galaxy.
    Cheers
    Roger
  19. #39
    Registered
    Jul 2012
    106
    I bought 5pcs of 15A/60VDC (STM32F103TBU7) based servo drivers at $38.00/pc and the heatsink requirement is nothing more than a small strip of 1in wide aluminum flat-stock due to the very low IRDs of the FET's used and this price was based on a run of 200pcs.
    While I have the eagle files for this driver, making more of this driver is not an option because what is lacking is firmware and the one person who has working firmware is no longer sharing it after others like yourself decided you didn't want him around here contributing to any projects.
    Basically what I see is a lot of people like RCaffin who are actively sabotaging viable projects and products and for the life of me I can't understand the logic which dictates that an inexpensive servo solution should not be available to the home/hobby user but it appears that many people don't want it as they make efforts and expel energy preventing it.
  20. #40
    Gold Member
    Dec 2007
    2148
    I couldn't see it anywhere but are you planning on producing 3 axis boards?
    Very cool looking project, major props getting it out there!
    cheers, Ian
    It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
Page 2 of 8 1234
  1. Replies: 30
    Last Post: 08-24-2015, 10:03 AM
  2. Smoothie CNC controller, Open Source.
    By Rolf_K in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 01-15-2015, 07:41 PM
  3. CNC Controller with Arduino - open source
    By Christian Knüll in forum Open Source Controller Boards
    Last Post: 12-22-2012, 10:46 AM
  4. Open Source CNC Controller Specification
    By gregmary in forum DIY CNC Router Table Machines
    Last Post: 12-05-2005, 04:58 AM
  5. BEST Open source Controller ?
    By Seventeen in forum Open Source Controller Boards
    Last Post: 09-22-2005, 12:27 AM
