Originally Posted by
sharpen047
Hey guys, been looking to hook up my cnc xpro v5 controller to my cnc machine i have just built and am having trouble setting up spindle control. Coming from a G540, ive never set up the automatic spindle control.
Ive been looking for hours now on how to setup the different settings in the wj200. i have downloaded installed and connected via the usb port on the inverter to change settings etc.
My goal is to use the 0-10v to control the spindle speed but it doesnt seem to do anything. i have sent M3 S12000 in terminal and the light comes on to indicate the spindle relay(which reads 5.12v)
I have the negative from the controller going to (L) and the 10v going to (O).
ive set my settings in the vfd base and max freq to 400, 220v, and 8 amp as indicated on the spindle motor.
A001 01
A002 01B
B037 0
A082 220
A004 400
H003 2.2
When i run H001 2, and i sent M3 S12000 i get 180Hz output on the screen of the vfd, but the motor doesnt spin.
When connected to USB i can control the spindle using the frequency and direction buttons on the control tab and the motor works as intended.
i feel like i am missing some sort of setting in the vfd, any help would be appreciated thank you.
