585,758 active members*
4,723 visitors online*
Results 1 to 12 of 12
    Aug 2005
    58
    Damaged Reci Tube. Salvageable?
    Hi All, new here.
    I inherited an old RECI W4 tube which has been sitting in storage for a couple years. It has two broken areas in the glass. First is the water inlet or outlet tube, which I am pretty sure I can rig up something involving 3D printing and some silicone to connect the hose and keep it all sealed. The second area is a broken off piece in the outer tube. I am not sure what this was for and looks to me like a remnant from the manufacturing process.
    Attachment 431988
    Attachment 431990
    Looks like it is this part store photo
    Attachment 431992
    Question is if this is likely broken or salvageable? Does the outer tube actually contain any gas? Can I just plug that hole and call it a day?
    Second question. I have a DY13 power supply which is supposedly matched for 130W max RECI W4. Is it possible to wire this up to a smaller tube say 60 or 80 watt?
    Nov 2010
    787
    Re: Damaged Reci Tube. Salvageable?
    This is garbage.
    CNC lasers, constructions, service
    Aug 2005
    58
    Quote Originally Posted by cinematic2 View Post
    This is garbage.
    Do you think it will at least fire to be able to test other components?
    Is it that the gas is gone or the insulation is compromised?
    Nov 2010
    787
    I don`t think, I know. Do not loose you time. And mine.
    Jan 2008
    940
    Why would it waste your time.
    Aug 2005
    58
    I am building a custom laser setup to do a very specific kind of engraving which is not commercially available (etching the inside surface of a 1" hollow tube). I am new to this so I was hoping to get some learning mileage and wear on a free tube before spending $1k+ on a new RECI W4. So if anyone has anymore insight on WHY these two cracks cannot be repaired, I would love learn.
    Nov 2010
    787
    There is a high vacuum inside this type of laser with a vestigial amount of precisely selected gas mixture.
    Jan 2008
    940
    It doesn't cost you any thing but your time to see if it will work. As long as the inner tube is ok then the outer tube is just a water cooling cover
    Nov 2010
    787
    Outer tube IS NOT a cooling water jacket :-D
    Jan 2008
    940
    If it is not just a water jacket then what is it. It can't be filled with a gas as the are shipped with open ends. Why do they tell you to remove all the bubbles from the water.
    Nov 2010
    787
    fixtureman1, you have no slightest idea how DC laser is build and how it works so stop this foo....sh discussion.
    Water cooling jacket is inside laser. Between inner and outer tube.
    There are 4 tubes inside.
    1. resonator for laser action
    2. cooling jacket
    3. mixture tank connected with resonator for mixture exchange
    4. spiral tube to give used (hot) mixture appropriate speed to leave resonator as quickly as possible. Professional lasers use high vaacum pumps.
    Aug 2005
    58
    Thanks guys. Took a closer look at all this and decided to scrap it. Looks to me that the outer tube is more than just a protective enclosure which is what I assumed. It's a dumb design that RECI leaves this critical piece relatively unprotected.
  1. Laser tube Reci w8
    By smart81bg in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-23-2019, 03:11 PM
  2. RECI W4 100 Watt Tube
    By Winger61 in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 06-24-2018, 02:37 PM
  3. Shenhui (RECI 150 watt tube) not going through entire tube. Sparks!
    By stonepercussion in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-12-2017, 07:40 AM
  4. poor power on 100w reci tube. tube is new. 1290 laser.
    By nate in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-05-2015, 07:31 PM
  5. problem with PSU wiring for 80W Reci CO2 tube - only getting 4 mA output to tube
    By gbatten in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 01-06-2015, 12:53 AM
