585,883 active members*
4,764 visitors online*
Results 1 to 2 of 2
    Feb 2023
    Y Axis Drifting during run
    I have purchased a new Chinese 1325 cnc machine from china, but when running a file on this after a few minutes the Y Axis seems to start drifting and losing its position. At the end of the file if I go to zero point it is completely off on the Y axis. Can anyone give me any suggestions as to why this could be happening?
    CNC router has servo motors, and is running on NcStudio software.
    I am based in UK, West Yorkshire, I would be willing to pay someone to fix this for me as this is quite urgent.
    Thank you
    Jan 2013
    474
    Quote Originally Posted by solzy View Post
    Thank you
    First mark the axis motor coupling to motor shaft and leadscrew, with a marker pen.
    It's possible it's slipping little by little, then try tightening both coupling locking screws. Check the Y axis leadscrew nut also.
    Also, try unplugging and reseating all y axis cables, with power off.
  1. Problem with y axis drifting
    By cooke86 in forum Mach Software (ArtSoft software)
    Last Post: 10-12-2016, 11:04 PM
  2. Y-axis drifting, why?
    By andersschroder in forum X3/SX3/G0619/G0463
    Last Post: 10-24-2013, 12:36 PM
  3. Z axis drifting
    By Absolute Steve in forum CNC Machine Related Electronics
    Last Post: 02-28-2011, 03:04 AM
  4. Y axis drifting
    By Realmseeker in forum DIY CNC Router Table Machines
    Last Post: 05-24-2010, 08:24 PM
  5. Z-axis drifting down
    By Vogavt in forum DNC Problems and Solutions
    Last Post: 10-23-2007, 09:04 AM
