Hello,
I have a 48v AC stepper motor and need to buy a driver to control the motor.
I was looking ma860h driver. Someone have feedback about that driver? Any other suggestion?
Best regards.
Hello,
Best regards.
Every stepper I've ever seen ran on DC. Are you sure yours is AC? Are you sure it's a stepper motor?
Well, not so sure.
Motor ref: HY200 3437 0660 AK04
I cant find all the information about the motor. I know its hybrid, have 4 leads, 2 coils and 6.6A phase current.
I assume it was AC because with the motor have a transformer to 48V but i dont find any retifier circuit, but i can be wrong.
Can i make any test to see if it is AC or DC ? maybe using it as generator ... ?
Thanks for your answer.
Hi Jacare - A stepper motor runs on pulses provided by the driver. The driver can accept AC or DC and the driver rectifies it onto the correct waveform. Peter
Yes you got it. Check the input voltage specs for the driver in its manual. Good luck Peter
