just put some tramming tools up.
Garage Sale
Hoss
Garage Sale
Hoss
http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
What are you using on your machine for power drawbar now?
Inner Vision Development Corp. - http://www.ivdc.com
Website Design & Development. Shopping Carts, SEO and more!
The PDB3.
Projects3
Hoss
Found my original G0704 control box if interested. It's the original before they ran into problems with them. Worked perfect for me.
Garage Sale
Hoss
Found my old beltdrive pulleys to get rid of, both v-belt and 2 speed XL.
Garage Sale
Hoss
update, timing pulleys are gone. both sets gone.
Linear Rails or big treadmill motor anyone?
NSK Japan SH200520AND1 Linear Rails 3 Pairs | eBay
3 8 HP Treadmill Motor | eBay
Hoss
Anyone looking to make a hydraulic power drawbar this would be the ticket, I never got to the project. Half the price of others.
SAMSOMATIC TA6007.4X1 PNEUMATIC HYDRAULIC TRANSDUCER
Hoss
Guys - How tight is everyone tightening the jam nuts? I have a problem with the Z axis where if i tighten the jam nuts too much, i get serious wobble (like .250) on the screw. Also on the instructions it shows hoss add AC, top endcap, .025 shim, AC, jam and another jam nut, but on the video it shows AC, .025 shim, endcap, .025 shim, a (washer?) and then two jam nuts. Which is correct?
Making chips, day by day
Use both shims.
Hoss
Thanks hoss... Also, how tight should the jam nuts be? should the first one be very tight and the other finger tight or what?
tighten the first so it spins freely with no slop and jam the second with the first careful not to overtighten the first, usually takes a few times to get it right.
Hoss
Got it. Thanks again hoss!Should there be any side to side play from the endcap to the screw? I found that to eliminate that play, I had to tighten the jam nuts to a point that the ballscrew didn't want to move
Sent from my Nexus 5 using Tapatalk
likely from the ac bearing which is a tiny bit smaller in diameter than the pocket, a thin strip of shim around it will solve that.
Hoss
bgriggs your inbox is full.
The air cylinder is 3.950 inches in diameter which would be the widest part so if you have 2 inches clearance from the center of the drawbar to the motor it should fit.
Hoss
Sadly I only have about 1 1/2" clearance towards the column. The sides are clear but not the back.
Joescnc 4x4 R&P Router, Minimill, Minilathe, CNC Foamcutter, laser cutter, Vectric Aspire. http://makermasters.com, http://themakersguide.com
Has anybody come across an interesting pocket on their saddle? Is it a defect or intentional modification for the cnc conversion?
Attachment 329436
Head spacers. Check.
Bill
Hoss, can you give me a rough idea of the length and depth of your new chip tray. I am going to make one this weekend.
Bill
