585,996 active members*
4,497 visitors online*
Page 1 of 2 12
Results 1 to 20 of 22
    Apr 2015
    12
    Parameter password reset
    Does anyone know what the password would be on the chinese engravers to reset the parameters to the default settings?
    Jun 2014
    611
    Re: Parameter password reset
    Hello, which controller do you use? different controller has different password. our machine use RDC6442G controller.
    How to use laser software - Thunderlaser
    Apr 2015
    12
    Quote Originally Posted by Nolan Yang View Post
    Hello Nolan. That is the same controller that we use as well.
    Jun 2014
    611
    the password is rd8888, please have a try.
    Apr 2015
    12
    We tried that password and it did not work.
    Jun 2014
    611
    Hello Stephanie, have you solved this problems? sorry for the late reply, I just come back from holidays. please try HF8888.
    Mar 2013
    5
    Hello Nolan, HF8888 does work for factory default, thank you (I am also using the RDC6442G)! Unfortunately it messed up my y-axis. I was having problem with my PWM set incorrectly for laser control, is there a separate password for factory parameters to fix both my Y-axis issue now and the PWM? (HF8888 and RD8888 do not work for fact para)
    Jun 2014
    611
    you can try CC8888
    Mar 2013
    5
    Hi Nolan, that password worked thank you!
    Mar 2013
    5
    Nolan, one last question, I have greatly appreciated you help. Is there a vendor default for baseline redsail style machines using the RDC6442G controller? As seen in the thread:
    http://www.cnczone.com/forums/genera...-software.html
    With the images of:
    Attachment 279224Attachment 279226Attachment 279228
    Is there information available for the Manufacturer Settings, ie the file, or just the numbers?
    Thank you so much!
    Doug
    Jun 2014
    611
    Hello Cogolith, every company has different setting, so I don't know vendor default for your baseline redsail machine, you should ask your supplier for help.
    May 2015
    Hello Nolan, I was having problem with RDC6442G controller. When the controller is started, the LED 13 on the controller lights up, and on the display there is an image "Connecting to controller...".
    Further the controller isn't loaded. How it is possible to solve this problem?
    Jun 2014
    611
    Hello woodex, sorry for the late reply, I don;t see this message before.
    I don't face this problem before. when our controller is started, the LED 12 lights up not LED 13, I think our contact method is a little different.
    please contact with your supplier. Thank you.
    May 2015
    Nolan, thanks for the response.
    Mar 2017
    7
    Hi Guys,
    Have you found a fix for this? I also made a mistake of doing both Set Fact Para and Def Fact Para reset since I was trying to fix the skipping issue but it messed up the axis and is now creating weird noises that were not present before. How do I set this up? And is there any firmware updates to fix the skipping issue?
    Hoping for your reply.
    Thanks,
    Apr 2017
    4
    I have the same problem, I had to perform the two resets to fix a over run issue I had when doing a scan. Now when I turn on the machine it wants to about 1m out side the machine on the top left, and I can't workout how to set it's home default for start up.
    Aug 2015
    Quote Originally Posted by MrMusk View Post
    New to the forum Hi
    I’m having the same problem with red/black Chinese 7050
    Can anyone point me I’m the right direction ? Thanks ????
    Apr 2017
    4
    Hi Stu44,
    The way I fixed it was, I had to play with the setting for the X & Y axis, depending of which way it is out. I had to flip them or change them positive to negative or visa-versa. See Cogolith’s post below, for the screens. To get these in RD Works go to vendor setting, password is rd8888.
    Jul 2020
    I bought a Chinese laser cutter model SH-G350 from Amazon and came with no password or information to contact anyone. Can someone please help me?
    Also says RDC-V8 0063
    Jan 2008
    940
    Try rd8888 as your password
Page 1 of 2 12
  1. parameter reset
    By karthick in forum Fanuc
    Last Post: 06-21-2014, 11:36 AM
  2. CNC-2DA cnc software password reset
    By stevenburton in forum CNC Wire Foam Cutter Machines
    Last Post: 07-16-2009, 09:55 AM
  3. machine reset parameter
    By priyo in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-28-2007, 07:45 AM
