585,931 active members*
5,604 visitors online*
IndustryArena Forum > WoodWorking Machines > Uncategorised WoodWorking Machines > Dust boot from PVC pipe for water cooled spindle
    Jan 2010
    76
    It so happens that my new 80mm water cooled spindle is almost a match to the ID of 3” PVC pipe so I decided to make a dust boot. I used what I had on hand which was a 45 and straight pipe. I don’t have much vertical distance between the holder and the collet, only about 3” so I knew I was going to have to squash the 45 to minimize the height. I traced the radius onto the 45 and cut it out with a bandsaw. Then I used screws, glue and little nails on An angel to bond the two pieces together. You always need mechanical anchors for plastic as most glues just aren’t good enough. Squishing the fitting made it wider than the straight PVC so I filled the gap with a mixture of wood dust and epoxy. I primed it with a plastic primer and painted with hammered black. I made a small ring at the bottom that I will attach a brush to. Since the ring slides off I can make different size brushes for different cutting tool lengths
    Jan 2010
    76
    Attached Thumbnails Attached Thumbnails 071E2BB1-7005-458A-85B1-44C696300003.jpg   E292203F-6CC8-4B45-ABE6-18B97AFE67E2.jpg   1CFE7D2F-2265-46F1-A936-B2F8039A2064.jpg
    Jan 2010
    76
    Quote Originally Posted by basskitcase View Post
    2nd set of photos
    Attached Thumbnails Attached Thumbnails 7ED9E40C-8E03-4D7C-990F-BF72297B531B.jpg   F2B1D65C-D537-499C-9B39-39534B0136C9.jpg   0C99EB36-8299-42FA-9738-C34BDCFD1AF5.jpg
    Jan 2010
    76
    2nd set of photos
    3rd set
  1. Spindle ER11 water cooled VS. ER16 air cooled
    By joaopcrodrigues in forum DIY CNC Router Table Machines
    Last Post: 11-06-2018, 05:47 PM
  2. Crazy Idea - converting Air Cooled spindle to Water Cooled
    By BanduraMaker in forum DIY CNC Router Table Machines
    Last Post: 01-20-2018, 02:29 AM
  3. Water pump for water cooled spindle
    By bballish in forum DIY CNC Router Table Machines
    Last Post: 03-01-2016, 02:40 AM
  4. Water cooled 2.2 KW Spindle water fitting
    By dfmiller in forum DIY CNC Router Table Machines
    Last Post: 11-26-2013, 06:21 AM
  5. water cooled spindle vs air cooled
    By ken2010 in forum Chinese Machines
    Last Post: 10-21-2013, 06:03 PM
