585,978 active members*
4,130 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > Adding user toolbar buttons in PlanetCNC TNG software
Page 1 of 2 12
Results 1 to 20 of 28
    Nov 2015
    260
    https://planet-cnc.com/adding-user-t...-tng-software/
    Does this also work in the TNG v2 software?
    Jun 2017
    143
    Re: Adding user toolbar buttons in PlanetCNC TNG software
    It definitely does, with even more options. If you look for threads that I have posted in you will find my questions that where answered by the awesome developer.
    I have buttons that control my vacuum, compressor etc via the web and sonoff devices.
    Simon
    Feb 2011
    138
    I have add just 3 more button, that is vhat I need, look to my post's there is whole zip you need
    Nov 2015
    260
    Quote Originally Posted by maki View Post
    I can't find a .zip file in your posts. Can you remember the topic name?
    Jun 2017
    143
    Have a read of this thread and see if it answers your questions.
    https://www.cnczone.com/forums/plane...ns-solved.html
    Nov 2015
    260
    And that's where my problems begin. I understand ...
    To create button for "User Command" use this:
    cmd: "Machine.User_Commands.UserCommand_1"
    ... Not.
    I have no idea where to find the file. Or can I have it created first?
    what does cmd mean?
    Nov 2015
    260
    OK, i find the .zip. i will try it ...
    Jun 2017
    143
    You need to create the files in your profile directory as in the old versions, otherwise it just uses the internal defaults. You can either just add to existing toolbars, or completely remove the default and do your own. You turn off the defaults in Settings->Toolbars->Buttons (hide). Doing that gives you complete control. The icons.zip file attached by planetcnc in that thread has example files.
    Nov 2015
    260
    OK. I have now got a button.
    The button should e.g. Execute M8.
    How is the code that it does while the machine is processing GCode.
    Second question is. the button should behave like a standard button. It should have a yellow background when active. If you press it again, it should execute a different code. Is that possible?
    Jun 2017
    143
    This is all possible. The thread I linked has lots of useful info, I suggest you read it all carefully. Sorry it is late here and I need some sleep. If you get stuck I can send you an export of my profile. It is massively customised and even has the ability to turn on/off stuff using my home automation. Let me know if you get stuck.
    Also the icons for buttons are best done as SVG files (from memory with a 50x50px workspace. Look at the ones in the icons.zip file to check the spces.
    Cheers
    Simon
    Nov 2015
    260
    Your profile folder will definitely help me. But tomorrow is another day. Good night!
    Feb 2011
    138
    sorry for late reply....
    Attached Files Attached Files
    Nov 2015
    260
    Danke!
    Feb 2011
    138
    Just pay attention of exit pins, in file are MY OWN adjustemt !! Yours can way diferent!
    Look at top of the window, three new button apears...Click image for larger version.
    Nov 2015
    260
    Unfortunately, it doesn't work as requested.
    When pressed, button 1 should execute code M63 P1 Q50 and light up yellow.
    If the button is pressed again, it should have the code code M63 P1 Q0 and the yellow light should go out.
    expr: "cmd('Machine.Start_Code', 'M63 P1 Q50')" "Button 1" imagechange="False" stroke=1 tooltip="PWM Set to 50"
    Another problem is that the button only works if no G code is processed.
    Feb 2011
    138
    Works for me, I have connected ext (4 in my case) with button nr.1, and in PP I have defined how - what it shoud do. Here is the part from PP which is delivered with TNG:
    begin HEADER
    "( [TP_FILENAME] )"
    "( File created: [DATE] - [TIME])"
    "( USBCNC Postprocessor )"
    "( Material Size)"
    "( X= [XLENGTH], Y= [YLENGTH], Z= [ZLENGTH])"
    "([FILE_NOTES])"
    "(Toolpaths used in this file"
    "([TOOLPATHS_OUTPUT])"
    "(Tools used in this file: )"
    "([TOOLS_USED])"
    "[N]G00G21G17G90G40G49"
    "[N]G80"
    "[N]M62 P2 Q1"
    "[N][S]M03"
    "[N] ([TOOLNAME])"
    "[N]G00G43[ZH]H[T]"
    "[N]M62 P4 Q1"
    "[N]M62 P6 Q1"
    "[N]M62 P8 Q1"
    "[N](Toolpath:- [TOOLPATH_NAME])"
    "[N]([TOOLPATH_NOTES])"
    "[N]G94"
    "[N][XH][YH][F]"
    meaning, which output shoud do something. Is the same if you go "machine/exit/output (1-8)
    Nov 2015
    260
    I would like to mention that I am not a programmer.
    Where should I copy the code to?
    Feb 2011
    138
    The code is in PP delivered with TNG software. It is in "Program Files\Planet CNC\Samples\Postprocessors\*.*" There is 3 of them, I dont know which one u are using... This is from Vectric PP.
    By the way, If u copy files from zip file shoud work without anny G code. Obtain if on "ext" buttons in TNG changing from red to green and back. Then u shoud just connect proper ext (1-8) from MB to do something fe. make connection with some SSR, start cooling, vacuum, etc.
    And I am not a programmer ider....;-)
    Nov 2015
    260
    The three buttons from the ZIP of you work. With this I can only switch the outputs on and off.
    But I want to switch a PWM signal output with it. To do this, code should be executed by pressing the button. But then it doesn't work with the yellow highlighted.
    Jun 2017
    143
    This is how I do toggle buttons.
    In BtnTop.txt I add a line for the button
    Code:
    expr: "startcode('M910')" "" image="Icons/IMG_Compressor.svg" tooltip="Compressor" imagechange="true" stroke=3.0 updown="_compressor == 1" updatefast="true"
    This will use the variable _compressor to maintain the state. The you need to create a script file something line this:
    Code:
    (print,Start M910)
    O<Test> if[NOTEXISTS[#<_compressor>]]
      #<_compressor> = 0
    O<Test> endif
    O<Toggle> if[#<_compressor>]
      #<_compressor> = 0
      M63 P1 Q0
    O<Toggle> else
      #<_compressor> = 1
      M63 P1 Q50
    O<Toggle> endif
    (print,End M910)
    Hope this helps. Once again I suggest using svg's for you buttons as they scale properly if you change the size of the toolbar.
    Simon
Page 1 of 2 12
  1. Is the PlanetCNC software license transferable?
    By retrosmith in forum PlanetCNC
    Last Post: 01-23-2019, 02:25 AM
  2. Adding buttons to Mach 3
    By Jkountz in forum Mach Wizards, Macros, & Addons
    Last Post: 02-24-2013, 07:48 PM
  3. Some help with EMC2, adding buttons....
    By Vegabond in forum LinuxCNC (formerly EMC2)
    Last Post: 08-27-2009, 05:37 PM
  4. Plot toolbar and user interface
    By single phase in forum NCPlot G-Code editor / backplotter
    Last Post: 10-11-2006, 08:39 PM
