0 active members*
4,653 visitors online*
Results 1 to 14 of 14
    Feb 2008
    5
    Exclamation HAAS TL 1 Brake
    Hey,
    Was wondering what everyone is using as a brake on their chuck. According to out resources the TL 1 does not have one. Thats kind of a pain for certain situations.
    Nov 2007
    1702
    Nope, no 'brake' on the TL-1. I use a crescent wrench on one jaw when I'm tightening jaws or other hardware.
    Greg
    Jul 2005
    12177
    Quote Originally Posted by Donkey Hotey View Post
    With something laid across the linear guides so that when the wrench slips out of your grasp it does no damage?
    You can get spindle orientation which acts as a brake but it is not locked rigid.
    Nov 2007
    1702
    Quote Originally Posted by Geof View Post
    Yeah...uhh...you weren't watching me were you? Yeah, I do that every time.
    Actually, I only did it once (installing the chuck). And now that I think about it, the backplate has nowhere to use a wrench. I installed two of the chuck bolts and used a pry-bar between them to tighten the backplate.
    I miss just switching my old manual lathe into low gear. The biggest annoyance has been the chuck wrench, adjusting the chuck. The wrench is now a two-handed job to 'spin' the scroll open or closed. The weight of the wrench just wants to rotate the chuck the minute my hand comes off of it.
    Greg
    Jul 2005
    12177
    ....The weight of the wrench just wants to rotate the chuck the minute my hand comes off of it.
    Guess whose TL1 has a little ding in the linear guide just below the chuck? Fortunately so far forward the bearings trucks never reach there.
    I agree with the chuck key being awkward to use. I cut the arms down to about 1-1/2" long so I can spin it fast with a finger then use a piece of tube as an extender for tightening. I also have it hung from a length of chain up to a hook in the ceiling so I cannot close the door on the machine with it in place.
    Jul 2005
    181
    Enter 0 speed and the chuck will keep it's position. I use it often when I tighten bolts when switching chuck.
    Dec 2006
    Quote Originally Posted by Wiseco View Post
    Thank you! I believe yours is the best solution to the original problem, and although I did not ask the initial question, I can certainly make good use of your suggestion. Thanks again.
    Jun 2006
    47
    I have a wrench that fits in the notches on the backplate. It allows you to remove two bolts at a time, you just rotate the position 90 degrees and remove the other two bolts.
    Mark Hockett
    Jul 2005
    12177
    The other way to do it is just bash the Allen Key with a plastic hammer and let inertia keep the chuck or spindle from rotating much.
    Jun 2006
    47
    Geof,
    That works for removing but I like to use a torque wrench for installing the backplate or my collet nose. It helps prevent overtightening that could cause damage to the spindle threads.
    Mark Hockett
    Jun 2006
    47
    Here's a picture of the backplate wrench,
    Its crude but it only took about 45 minutes to make. One of these days I will run it through my anodize line and make it red to match handles and collet closer stabilizer on the lathe, here's the stabilizer.
    Mark Hockett
    Nov 2007
    1702
    Thanks for posting those pictures. Until I saw that, I hadn't considered how I was going to anchor the Dunham air closer that I bought.
    Greg
    Jul 2005
    12177
    Quote Originally Posted by Mark Hockett View Post
    Geof,
    Mark Hockett
    You use a "torque calibrated plastic hammer"
    But you are correct it is not really good practice, but I have played around a bit seeing how tight they are after the hammer approach and actually with a plastic hammer it is difficult to go too tight.
    I like your wrench and I am interested in the collet closer. How does that work? It would seem to be air opened and air closed by the two air lines but does it close and mechanically lock or is air pressure maintained. If air pressure is maintained how is the locking force transmitted, by a big thrust bearing?
    Dec 2010
    8
    Re: HAAS TL 1 Brake
    Mathews Engineering offers an aftermarket spindle brake for TL series lathes:
    https://www.mathews-engineering.com/...and_newer.html
  1. Converting Conventional Hydraulic Press Brake to CNC Press Brake with PC
    By aadityadengle in forum Uncategorised MetalWorking Machines
    Last Post: 08-13-2023, 05:23 PM
  2. 600mm Box bend brake (Finger Brake, pan Brake)
    By RotarySMP in forum Bending, Forging, Extrusion...
    Last Post: 11-01-2015, 10:24 AM
  3. Haas TR160Y Air Brake Problem
    By jimcooptcam77 in forum Haas Mills
    Last Post: 12-06-2011, 09:37 PM
  4. brake
    By rotsenmendoza in forum Mach Software (ArtSoft software)
    Last Post: 04-15-2011, 11:39 PM
  5. Need a box and pan brake
    By J-Mccoin 2009 in forum Want To Buy...Need help!
    Last Post: 12-11-2009, 10:10 PM
