585,886 active members*
6,218 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Laguna SmartShop 1 Transformer Problem
Results 1 to 6 of 6
    Apr 2018
    6
    Hi all. First time asking a question. Most of the time I can find general answers that I can work with, but this is an electrical problem and I think I need something more specific.
    We have a Laguna Smart Shop 1. There are two transformers (JBK5-800), stepping down from 220 to 130, running the z, x, and two y stepper motors. One of the transformers blew in the middle of a job (very light pocket cuts, so hardly any load) and blew the breaker too. I reset the breaker and tried to turn the machine back on. As soon as I switched on the main power the transformer immediately popped, sparked, and smoked while also blowing the breaker again. I called Laguna and they recommend replacing the transformers assuming it was due to the age of the transformers. I installed the new transformers and it did exactly the same thing.
    Right now I'm trying to chase down a possibly compromised wire that's shorting out the system, but no luck so far. Any advice would be helpful. Am I barking up the wrong tree? Am I missing something obvious? Once I find the smoking gun are my new transformers useless now because they popped?
    Thanks!
    Jan 2010
    77
    Re: Laguna SmartShop 1 Transformer Problem
    Disconnect the power wires from the drivers and see if it still pops the breaker. Could be a bad driver. If it doesn't trip breaker with all drivers disconnected, connect one at a time and try each time to see which one is the culprit. Always turn off all power before making changes to test.
    Apr 2018
    6
    Quote Originally Posted by kenrbass View Post
    Thanks kenrbass! That's a great suggestion. I'll try that and let you know how it goes.
    Apr 2018
    6
    So interesting update. First I disconnected the power lines into the transformers. So, in theory, there shouldn't be any power going through the transformers. I turned the power on and the transformers still blow. Which means that power is backing up into the transformers from another source. I disconnected the power wires to the controllers (like kenrbass suggested) and nothing happened. I turn the power off, connected one controller at a time, and the transformer blows every time.
    Jan 2010
    77
    your last reply is not logical.
    Apr 2018
    6
    I agree. Imagine my surprise when the power in was disconnected but the transformer still blew.
  1. Laguna SmartShop 2 or Vcarve issue? - Tool Lengths changing!
    By dangerfox in forum CNC Machining Centers
    Last Post: 10-01-2019, 04:23 AM
  2. Any Laguna Smartshop Laser users out there?
    By Willywonka321 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-11-2017, 08:40 PM
  3. Transformer problem!!
    By Cferrell84 in forum Fadal
    Last Post: 05-29-2016, 10:07 PM
  4. rover 23 24 volt transformer problem
    By paulhayden in forum European Club House
    Last Post: 03-17-2016, 01:31 AM
