585,930 active members*
3,918 visitors online*
Page 2 of 6 1234
Results 21 to 40 of 103
  1. #21
    Jul 2003
    586
    Re: David A's Benchtop CNC Version 2
    Using the linear rails in this manner is "rigid enough? I would think there would be a serious resonance issue.
  2. #22
    Oct 2009
    733
    4thseal, thank you for the question.
    Functionally, I would say the arrangement of these linear shafts is in line with their intended purpose.
    They slide in two ball bushings in a linear direction with axial and radial loads applied along the linear shaft.
    In this case, instead of being typically on the Y or X axis, they are used in the Z direction and instead of the
    bushings moving, the shaft moves.
    Keep in mind that these are two 1.18" diameter hardened steel shafts over a span of about 8" and
    the unsupported portion of the shaft never exceeds the ball bushing spacing at any time.
    I am pretty sure Peter (peteeng) can show some quick calcs how the two 30mm shafts would compare
    to a conventional aluminum extension plate most designs use.
    To get back to your original question, I have not observed any resonance issues whatsoever on the
    prototype machine over the two years I have been testing it on various materials.
  3. #23
    15362
    Quote Originally Posted by davida1234 View Post
    Hello all,
    Some of you might remember, I had posted a thread called "David A's New 2x3 Benchtop CNC" about two years ago.
    https://www.cnczone.com/forums/diy-c...h-top-cnc.html
    The machine has been running good and received quite a bit of changes in those two years so I thought I start a new thread showing the improvements I made since then.
    Good to see you back with more good ideas with your machine build
    Mactec54
  4. #24
    Jul 2018
    6334
    Hi David - The proof is in the pudding (prefer lots of chocolate sauce) no need for calcs, if you know it does the job. Keep Making Peter
  5. #25
    Oct 2009
    733
    Hey, good to hear again from you guys.
    On this build, I really concentrated on making all forces
    as much planar or inline as possible.
    I strongly believe that by minimizing any offsets and
    cantilevers you also minimize stress and deflection.
  6. #26
    Oct 2009
    733
    The sand ballast is finally dry enough for the top to be placed.
    There is a 1/4" HDPE sheet covering on top of the plywood:
Name:	Base finished.jpg
  7. #27
    Oct 2009
    733
    The machine frame is on the base:
    Attachment 463942
    Now the assembly of the machine can start.
  8. #28
    Oct 2009
    733
    Machine Assembly:
    Installation of machine feet:
    The four feet consist of 1" diameter SS bolts and nuts
    pressed into plastic bases with 1/4" screw-down holes:
    Attachment 463944
    Lift one side of the frame. I use a car jack for that:
    Attachment 463946
    Screw in the 1" bolt directly into the bottom of the upright profile:
    Do the same on the other uprights.
  9. #29
    Oct 2009
    733
    INSTALLATION OF Y/A-AXIS REAR CAPS:
    Parts of rear caps:
    Attachment 464030
    Puts a bit of glue to the backs of rubber bumpers and push into recesses.
    No screw necessary as they only work on compression.
    I used liquid tape for that but any glue will do:
    Attachment 464032
    Rear caps ready for assembly:
Name:	Rear Bumpers 3.jpg
  10. #30
    Oct 2009
    733
    Using the 5/16 cap screws, install rear caps to the back of Y/A beams:
    Attachment 464066
    Rear caps installed:
    Attachment 464068
Name:	Rear Caps 5.jpg
  11. #31
    Oct 2009
    733
    INSTALLATION OF Y-A RAILS:
    All rail mounting surfaces have been machined for flatness:
    Attachment 464182
    Y/A axis uses the shorter 20mm linear rails with flanged trucks.
    All trucks have been re-lubricated with Mobilux EP1 grease:
    Attachment 464184
    Install the self-centering T-nuts with 5mm screws onto the linear rails:
    Attachment 464186
    Make sure the grease nippels are facing outwards.
    Slide the linear rails with the T-nuts into the top groove of the profile:
    Attachment 464188
    Push the rail until it lines up with the front of the rubber bumpers:
Name:	Y_A Rails 5.jpg
  12. #32
    Oct 2009
    733
    Y rail and A rail on the frame:
    Attachment 464242
    Before tightening, wiggle the rails side to side to fully seat the T-nuts:
    Attachment 464248
    Slightly tighten the rails by starting from one end.
    Then go back to start again and fully tighten:
    Attachment 464250
    Once everything is fully tightened, use a piece of plastic and a
    hammer to seat the green covers over the screw heads.
Name:	Rail Covers.jpg
  13. #33
    Oct 2009
    733
    INSTALLATION OF Y/A CARRIAGES:
    Y/A carriages:
    Attachment 464390
    Remove the four dust covers and brushes on the carriages:
    Attachment 464392
    Attachment 464394
    Place them on the linear rail trucks, making sure the 5/16 threaded holes
    are towards the front of the machine and the notch faces outward:
    Attachment 464396
    Tighten the carriages to the trucks with M6 screws in an
    alternating pattern like you do with car wheel nuts:
    Attachment 464398
    Y/A Carriages on the machine:
Name:	Y_A Carriage 6.jpg
  14. #34
    Oct 2009
    733
    The gantry uses the 20mm narrow trucks:
    Attachment 464464
    Place the gantry beam on the carriages.
    Make sure the machined slot is towards the front:
    Attachment 464466
    Attachment 464468
  15. #35
    Oct 2009
    733
    Install the shorter linear rail like the previous rails:
    Attachment 464476
    Flip over the gantry beam. Linear rail fits between the carriages.
    Install the longer linear rail to the top like the previous rails.
    Upper and lower linear rails installed on the gantry beam:
  16. #36
    Jul 2018
    6334
    Hi David - How are you squaring the gantry rails to the table rails? Peter
  17. #37
    Oct 2009
    733
    Hey Peter - Final squaring of the gantry will be done after all the mechanicals are installed.
    For rough installation, the top of frame in the back is pretty square to the table.
Name:	Frame 1 arrows.jpg
  18. #38
    Oct 2009
    733
    Take the two front caps and install two 1/4" screws and T-nuts:
    Attachment 464514
    Temporarily install the end caps to the back bottom slots of
    the gantry beam at both sides as shown:
    Attachment 464516
    Slowly push the carriages and the gantry beam to the back
    until the caps hit the back beam of the frame:
    Attachment 464518
  19. #39
    Oct 2009
    733
    Gantry beam will be attached to the carriages using the 4 holes on both sides:
    Attachment 464520
    Align the holes on the carriages with the slots of the gantry beam.
    Make sure the gantry beam is still up against the rear frame
    and slightly clears the carriages on both sides:
    Attachment 464522
    DOING THE INSIDE SCREWS FIRST, use a magnet stick to push the
    T-nuts into the slot and install the 5/16 screws from the bottom:
    Attachment 464524
    Attachment 464526
    Once everything is tightened down, remove the end caps
    from the back of the gantry beam.
  20. #40
    Oct 2009
    733
    Install a bracket finger-tight on both sides of the gantry beam:
    Attachment 464556
    Install two braces on both sides.
    Make sure the holes are facing down and the short part is up:
    Attachment 464558
Name:	Gantry 14arrows.jpg
    Check for squareness:
    Attachment 464560
    Tighten down everything.
    Gantry beam braces are installed:
Page 2 of 6 1234
  1. David Rigotti - Hobby CNC Plans
    By KeithSloan in forum DIY CNC Router Table Machines
    Last Post: 03-30-2020, 01:51 PM
  2. David A's New 2x3 Bench Top CNC
    By davida1234 in forum DIY CNC Router Table Machines
    Last Post: 08-18-2019, 01:47 AM
  3. Replies: 1
    Last Post: 03-29-2017, 03:18 PM
  4. DIY David Steel CNC
    By Wineryrjd in forum DIY CNC Router Table Machines
    Last Post: 03-28-2010, 01:39 PM
  5. I built My CNC From David Steels Plans Now I need Feedrate help please
    By tager_rot in forum DIY CNC Router Table Machines
    Last Post: 09-09-2007, 07:52 PM
