585,951 active members*
3,894 visitors online*
Results 1 to 10 of 10
    Jul 2015
    6
    Treadmill Motor Speed Controller
    I'm in the process of building an electric honey extractor using a DC motor from a treadmill. I've watched countless videos on wiring up the main board with a POT but my board looks different to the ones in the video and I'm unable to fit the POT directly to the board, model number BC-1068). From my limited understanding I need a PWM but I have no idea how to wire one into the main board to make it work.
    The easiest way around this situation would be to buy a speed controller, would the one in the link below work?
    https://www.ebay.com.au/itm/38431401...3ABFBMvKyhhp1f
    Attached Thumbnails Attached Thumbnails Extractor.jpg   Motor.jpg   board 1.jpg   Board 2.jpg
    Dec 2003
    24221
    Re: Treadmill Motor Speed Controller
    That controller link shows what appears to be for an AC motor. You could possible use a bridge rectifier on the output but the power rating is a little low
    If not sure and need a very simple controller, purchase one for a Universal motor, hand drill etc, and place a bridge rectifier on the output.
    Albert E.
    Jul 2015
    6
    Thanks for the reply, is there anything off the shelf that would work?
    Jul 2015
    6
    ok so if I go with a 10000w voltage regulator with a 50a diode bridge?
    Dec 2003
    24221
    If the 1kw unit is a Triac style controller then a bridge on the output will run the DC motor.
    You would need to reverse polarity to change rotation direction.
    Albert E.
    Jul 2015
    6
    I'm not really sure if the one below has TRIAC or even what that is
    https://www.ebay.com.au/itm/38444223...frcectupt=true
    Jul 2015
    6
    Any chance you'd have a link so I know what I'm looking for?
    Dec 2003
    24221
    There are quite a few out there such as https://www.amazon.ca/Variable-Contr...93357030&psc=1
    You will also need a Bridge rectifier to add to the output.
    The Triac models are not as smooth as the PWM controllers, especially at low rpm.
    Albert E.
    Aug 2017
    45
    Look on youtube , there is lot on treadmill controllers .
    Jul 2015
    6
    I found the video below which explains it well, thanks for your time and help on this
    https://www.youtube.com/watch?v=_NmAFZMAfH8
  1. MC60 treadmill motor - eliminating zero speed start
    By chrismolloy in forum Spindles / VFD
    Last Post: 11-18-2017, 05:00 PM
  2. choosing the right speed controller for my treadmill motor/spindle
    By shiv15uk63 in forum Uncategorised MetalWorking Machines
    Last Post: 07-18-2016, 04:26 AM
  3. Controller for 230v 1.75 hp treadmill motor?
    By Azalin in forum Electronics
    Last Post: 03-31-2016, 07:09 AM
  4. DC Motor Controller & Driver 2hp ( 2kW ) Treadmill Motor
    By hesham morsy in forum Open Source Controller Boards
    Last Post: 01-27-2014, 12:50 PM
  5. 7x treadmill motor and speed controller conversion
    By maxboostbusa in forum Mini Lathe
    Last Post: 01-15-2014, 11:28 PM
