Re: Shizuoka AN-S mill information
The PDB stuff comes off pretty easy. The motor is a bit more complicated because of the variable speed pulley, and it's a bit heavy, around 125 lbs.
The easiest way to get the motor off is to open the motor pulley to its maximum and stuff in a block to keep it open. Then crank the other end to loosen the belt. For a block I used a piece of 1 1/2 inch pipe, cut in half lengthwise, about 1.5 inch long. Not much room to get it in there but it's doable. Weld a short length of chain onto the block so you can get it back out.
Jim Dawson
Sandy, Oregon, USA
