585,748 active members*
3,424 visitors online*
Results 1 to 11 of 11
    Feb 2005
    8
    PSU Voltage seems high.
    Hi
    I've just built up the hobbycnc 3-axis kit. Driver board is working fine off a bench PSU. I've built up the Psu with capacitor and rectifier supplied in kit and a 300VA transformer (30V,10A). Before I connected it up to the driver board I checked the output voltage and i'm getting 47vDC. I've checked it on a scope and i'm getting no ripple. This seems to be a bit high for the driver board. I've checked the input to the recrifier and it 29.7vAC so the transformer's giving the correct voltage out. Has anyone got any ideas why i'm getting such a high output and can the driver board take it or will it fry the chips?.
    Thanks in advance
    Matt
    Jun 2003
    1365
    This is because it rectifies the peak AC voltage which normal AC outlets peak ac voltage is around 170v. After it is rectified and filtered, typical output is 1.414x the transofmer output voltage.
    Jon
    May 2003
    550
    As Jon said, (apart from UK voltage being 220 ) rectified AC to DC increases the voltage by around 1.4. If you're after 30vdc you need a transformer output of ~21vac before rectifier. Don't connect your driver to 47vdc because it will blow it.
    Andrew
    May 2004
    198
    Quote Originally Posted by mnewsholme
    Hi
    Thanks in advance
    Matt
    30VAC(notDC) rectified makes @ 1.41 times DC volts. 30 times 1.42 equals 42.6VDC NO load. It will drop a volt or two under load. Your line voltage is over the input voltage. DO not use above 46VDC.
    Dave Rigotti
    Feb 2005
    8
    Ok I guess I'll swap out the 30v,10a transformer for a 24v,12a one. That should drop voltage down to a safe level but still have plenty of current in reserve.
    cheers :cheers:
    Matt
    24220
    You could always take some turns off, lowering the voltage will up the Current capacity, providing the wire size is OK, but 2amps extra coverage should be possible.
    Rough guide for a full Wave Bridge.
    VAC = 0.8 x (VDC + 2)
    IAC = 1.8 x IDC
    Al
    Albert E.
    Feb 2005
    8
    ok changed the transformer for 25vAC, 12A . getting 38.5vDC now.
    absolutely no ripple
    Matt
    24220
    Matt
    Remember the ripple has to be measured at the maximum load current to obtain the degree of ripple.
    Al
    Albert E.
    Apr 2003
    19
    Matt
    Matt, I have just finished my 3 axis board which works great off a bench psu (great job Dave :cheers: ), where did you get your transformer from?
    Steve
    Feb 2005
    8
    got it from rswww.co.uk. bit expensive but it was exactly the right rating i wanted. Part number is 223-3207. 25v, 6a toroidal. I think it was about 20 quid but then another tenner delivery :frown:
    Apr 2003
    19
    Thanks Matt, I'll get one on order
    Steve
  1. High Voltage wire
    By cncadmin in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-27-2012, 03:19 PM
  2. Power supply voltage too high
    By spoiledbrat in forum CNC Machine Related Electronics
    Last Post: 06-14-2005, 03:39 AM
  3. Transformer voltage seems too high for Gecko
    By bgolash in forum CNC Machine Related Electronics
    Last Post: 12-25-2004, 05:35 PM
  4. 5vdc from paralell port, not enough???
    By thuffner3 in forum CNC Machine Related Electronics
    Last Post: 11-23-2004, 01:07 PM
  5. Active High/Active Low
    By Sanghera in forum CNC Machine Related Electronics
    Last Post: 11-07-2004, 03:47 AM
