Hello,
I am a future user of the machine Syil X4.
Is it possible to connect the machine, my computer screen and on an electrical outlet (110V) using the same breaker? If so how much ampere I have to take?
thank you
Arthur
Hello,
thank you
Arthur
Hi Arthur.
Do I understand correctly?
You want to power the Syil + PC Screen + an 110V electric outlet all from the same breaker?
Depends on what Amp rating your breaker is.
You need to add together the ampage of the Syil + Monitor + whatever you will run from the outlet.
This total must not exceed the ampage rating of your breaker.
We run our Syil X4 from AC240V via 13Amp outlet without issue.
Hope that helps a little.
I run my X4 Plus, computer and monitor all from a single outlet. The outlet is on a dedicated 110V line with a 30 amp breaker.
