584,842 active members*
4,295 visitors online*
    Feb 2010
    Angry Tangent snaps
    HI all me again. I rely on snaps alot when I draw. ok it should be in there and i can not find it but is snapping to a tangent of a circle in bobcad, if so how is it done.
    I finally got the install cd yesterday and reinstalled and I did load one of the solid works file i was tring to load. so thanks for all the help so far.
    Joe
    Mar 2008
    29
    Up on the menu.....
    LINES
    drop down and choose
    TANGENT
    There is a TRIM button that will automagicly cut the entities at the point of tangency for you as well.
    It works great circle to circle tangent lines, end of a line to circle tangent but it does not recognize the mid point of a line.
    On the circle to circle tangent lines it recognizes inner or outer tangent points..... an "X" between the circles or a "V" to the outside of the circles depending on where you click on the dia for the approximate point of tangency.
    Feb 2010
    Thanks Mike
    I will have to go play with that when I get home.
    I am one that just got 23 because I did not like 22 and told them sothey gave me a good deal on 23 but I do think it is my last one. But I am starting to get used to strange way but it is though trying to keep the one at work straight with the one at home.
    Joe
  1. endpoint snaps how do they work or do they?
    By Bigguy63 in forum BobCad-Cam
    Last Post: 02-23-2010, 07:05 PM
  2. Arc tangent to an Arc
    By Bob Z in forum Mastercam
    Last Post: 02-26-2009, 10:48 PM
  3. line tangent from...
    By Castle1 in forum Rhino 3D
    Last Post: 09-21-2007, 02:08 AM
  4. tangent point
    By bob in windsor in forum MetalWork Discussion
    Last Post: 12-23-2005, 10:05 PM
  5. snaps
    By MPE racing in forum Uncategorised CAM Discussion
    Last Post: 12-10-2003, 12:28 AM
