:tired:
I have been using lazy cam to try to take simple designs or just basic text and engrave it on plexi. I noticed that When I make the image too small it does not copy all the fast travel lines as fast travel. Instead it keeps them at the engraving depth and I get a huge cut right where the Fast Travel path is suppose to be. Mach3 shows the line as blue even though LCam shows a red dash line. It sometimes even drops a few lines. If I Resize the image past 50x50mm and reload it to Mach3 it restores the lines back to fast travel. I am using a small machine. 50x50 is too big for most of my work. Even at that size or large it sometimes (most of the time) does not import all the fast travel lines as it usually misses 1 or 2 and sometimes even though L Cam is showing fast travel it will merge lines together or not post the FT lines as FT. Anyone have a similar issue? How do I fix this? I can not do custom engraving if there are travel lines engraved or missing parts to the text.
