585,917 active members*
3,481 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Is anyone using hall-effect limit switches?
Results 1 to 12 of 12
    Oct 2005
    2392
    Hi, I'm thinking of putting limit switches on my X Y and Z axes, and am considering using hall-effect sensors on the machine frame with little magnets mounted on the moving axes.
    Has anyone done this or have any input on doing this?
    It seems to be a good system with no moving parts and since I don't machine ferrous metals I can't see a down side.
    One of the best features is that they allow overtravel so I can put them some distance back from the end of the travel. So even if the steppers have had a major misalignment it can be easily detected with no chance of hitting the end stops.
    Apr 2007
    8082
    Quote Originally Posted by RomanLini View Post
    I wondered about it awhile back and looked up how they work. I decided that they would need additional support circuits that made them more complicated to implement than microswitches and decided against them. They have a change in resistance, not something approximating a contact closure. The additional circuitry would need to convert the resistance change into a logic level change. Not hard to do, but may be even more susceptible to noise glitching if not designed right.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
    Mar 2007
    51
    There is some digital type hall effect switches, like allegro A11xx series.
    Really simple to use but need 3 wires and not as rugged as simple switches.
    They have no bounce but switch position can be tricky to adjust.
    Jun 2004
    35
    Ive considered using prox switches but have yet to start the build
    Is the voice in my head bothering you?
    Feb 2010
    331
    read in one of the threads around here that they were popular in the joecnc fourms. might want to check there.
    Oct 2005
    2392
    Interesting.
    You can definitely get digital output hall sensors like mchabot said. But I'm not bothered by having to hook up a support circuit if it comes to that.
    Zygoat- I'll check the joecnc forums, thanks for the tip.
    Aug 2004
    3215
    Yes, several people are using them now, and I will also be using them on my new Rack and pinion machine.
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
    Oct 2005
    2392
    Hey Joe, (please ignore pop-culture Hendrix reference ) do you have a link to a thread etc discussing the sensor types and mounting details?
    The only thread I found was a real old one in the general electronics discussion section.
    Feb 2010
    331
    x2 i would like to learn more about them.
    Aug 2004
    3215
    Kent, Made a writeup with pictures for the members which remains on my site for our members, but here is a quick excert from the writeup, with just a little research you can get them working easily.
    Hall Effect Limit Switches
    12/26/09
    A Hall Effect (HE) transistor switches when in the presence of a magnetic field. They can be used to replace micro-switches to implement very accurate and reliable limit switches on a CNC machine. However, if the machine is used to cut ferrous metals, the swarf will be attracted to the magnets which will interfere with the trigger point of the switch. Therefore, they should only be used on machines that do not cut ferrous metals.
    I recently implemented HE limit switches on all three axes. The repeatability of these switches is better than I can measure with a dial indicator which means they are performing better than 0.001”. I chose to make the magnet stationary with the HE mounted to the moving carriage (you could also make the switch permanent and the magnet mobile if you prefer). I placed at each end of the axis, thus only one switch was required per axis thereby reducing wiring.
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
    May 2007
    767
    Hi
    Suggest you use the low price inductive proximity switches as these do not suffer from fouling with bits of stray steel. These switches are available from China via ebay for arround £6 each and I have been using them for the last 12 months with no problems for both limits and zeroing switches. These switches are available in different styles and are fully fluid proof and contain an indicator light to show the switch state.
    Here is a link for a sale that is current.
    http://cgi.ebay.co.uk/Inductive-Prox...item48393f62ae
    The point to note is that the distance in the data sheet for different materials is the gap between sensor and the operating block not the switching accuracy.
    For my money the inductive and capacitive proximity sensors have replace mechanical microswitches, magnetic hall effect and optical devices for most applications with the possible exception of high speed shaft rotation measurements.
    Hope this helps - regards Pat
    Apr 2007
    327
    I'm using them on my machine and they work fantastic! I have them wired directly to my G540, no other circuitry was necessary. I don't have the schematic handy, Mariss told me how to connect them. If you have a G540 contact him and I'm sure he can tell you how to wire them up.
    Gary
  1. Hall Effect Limit Switches
    By SCzEngrgGroup in forum Benchtop Machines
    Last Post: 09-06-2009, 02:12 AM
  2. orient tool for tool change Hall effect?
    By Luslugger in forum CNC Machining Centers
    Last Post: 04-25-2009, 12:24 AM
  3. Hall Effect Chopper
    By legomanww in forum CNC Machine Related Electronics
    Last Post: 12-20-2007, 09:11 AM
  4. Hall Effect Limit & Zero
    By Trebleplink in forum CNC Machine Related Electronics
    Last Post: 10-20-2007, 12:08 AM
  5. The relationship of limit switches to home switches.
    By MikeAber in forum CNC Machine Related Electronics
    Last Post: 11-04-2004, 08:28 PM
