hello,
I do an interface with a machine haas mini mill
Can I use the Ethernet port as the port rs-232 with the same commands? eg Q600 and Exxx
hello,
My cnc driver and stepper motor ,,when i jog, left and right only left is always running,it should be runs in different direction always left .......i knew there is a jumper on the main board for setting a direction.i try to set to right direction , i moved the jumpper ,,,, its the same problem, it jog always right dir ..
what do you think
