584,833 active members*
5,405 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > 1998 Hitachi Seki VM-40 MX-3 help? Will Pay.
    Jun 2006
    138
    Hello,
    Bought this machine for a decent price, powered it up and it had a servo drive erorr so I changed out the drive it powered up with no errors and worked fine.
    Untill I tried to do a tool change throught the MDI and the tool arm rotated without releasing the lock pin first and broke the arm. It is fixed again and I am looking for someone to help me out, With getting the ATC to work, I will pay for phone/e-mail support. I have the manual and I am knowledgable on the electonics and mechanical part of CNC machines, Just never did the machine setup part. I am not sure anything is broke just not sure. I think there is a macro in the controller that does the tool change and there is a way to manully step throught the ATC.
    Aug 2007
    138
    Yes, M-codes
    In the MDI
    and
    “maint” mode (toggle switch inside cabnet)
    M100 Arm swing in to spindle
    M101 Arm slide to spindle
    M102 Arm advance
    M103 Arm Turn Clock wise
    M104 Arm Turn CCW
    M105 Arm Retract
    M106 Arm slide to home position
    M107 Arm swing/return
    M108 Arm slide to Magazine side
    M119 Orient spindle
    so sequence is
    M119
    M100
    M101 at this position you can adjust the arm to fit your spindle
    tool clamp/unclamp Manual push button
    M102 at this position you can adjust the arm to fit your spindle
    M103/104
    M105 at this position you can adjust the arm to fit your spindle
    M106
    M107
    Dan Clemens
    Summerville, Ore
    Oct 2006
    669
    Where are you located? I'm in Casper, if you still need the help.
    Quote Originally Posted by wyobmf View Post
    Hello,
  1. Mori Seki - Fanuc 11T
    By brourke in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-15-2014, 05:14 PM
  2. Post Processor for Hitachi Seki Lathe
    By astro cnc in forum Mastercam
    Last Post: 02-11-2009, 02:20 PM
  3. Hitachi seki fanuc o-t comtrol
    By yukon517 in forum Fanuc
    Last Post: 10-14-2008, 01:23 PM
  4. Mori Seki Sl-15 Machine Parameters
    By MILLMANM in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-25-2007, 01:36 AM
  5. Mori Seki SL4
    By programmer1956 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-08-2007, 11:22 PM
