586,009 active members*
4,921 visitors online*
IndustryArena Forum > MetalWorking Machines > Hardinge Lathes > Hardinge Quest 51 Turret Help!
    Mar 2010
    My Hardinge Quest 51 X and Z batteries died and were replaced late last week. The X and Z axis were reset succesfully but now my turret doesn,t index to the commanded position. Example; I give T0101 command and turret indexes to T6 position. Please assist me, we are and down and I haven,t been able to get any assistance from Hardinge. Especially since Hardinge has had a big merger China thing goin on.
    Jul 2007
    34
    On the conquest, you hold zero return button and push turret index button. Turret will turn to station #1 and lock. I imagine yours is similar.
    regards,
    newc
    Oct 2009
    51
    Its the same process for your turret on that machine. Get your turret to be clamped on its last station(10 or 12) depending on what you have and reset the APZ parameter (1815). If the machine has a subspindle, its the "3" and if its a tailstock machine, its the "A". I could have those 2 swaped though so I would look for which one of those two that has the next bit (APC) a 1. NEVER change bit 5 in that parameter (APC), as that's telling the control the machine has absolute encoders. Good luck!
  1. Hardinge Superslant SB3 GN 3 Axis Lower Turret
    By LMartin in forum Hardinge Lathes
    Last Post: 09-17-2010, 03:42 PM
  2. Hardinge T51 turret problem
    By gtsraven in forum Fanuc
    Last Post: 04-13-2009, 12:52 PM
  3. Need Help With Hardinge Quest 65
    By SDBull16 in forum Fanuc
    Last Post: 04-23-2008, 05:00 PM
  4. hardinge tool turret unclamp message
    By knox in forum Community Club House
    Last Post: 01-13-2008, 09:00 AM
  5. Hardinge CHNC turret woes
    By Karl_T in forum CamSoft Products
    Last Post: 12-19-2006, 10:54 PM
