585,759 active members*
4,238 visitors online*
Page 7 of 21 5678917
Results 121 to 140 of 417
  1. #121
    maybe I should license the upstairs one too so I can avoid any problems in the future, how many computers can I have Mach on with 1 license.
    You can put it on as many as you want if they're not controlling a machine. If you use your machines for hobby use, you can use 1 license for as many machines as you have.
    But if you're making money with your machines, you need 1 license for each machine.
    As far as what doesn't work in demo mode, there are quite a few things. They used to be on the Wiki, but aren't there any more.
    500 lines of code.
    Run from here doesn't work.
    No threading in Turn.
    Can't remember any more.
    Also, if you don't install the driver, there are some additional issues you may run into.
  2. #122
    Jul 2009
    272
    single license will work
  3. #123
    Apr 2006
    3498
    Hi big-tex,
    Thank you for such a nice Auto Tool functionality.. I am running Mach3 Lockdown Version R3.042.040.... My Z-axis is set as following:
    When My Z-axis Moves up--->The DRO shows -ve value
    When My Z-axis Goes down --->The DRO shows +ve value
    I know it is against the standard practice but i have some special Gcode postprocessor files that generate Gcodes in this way... So i didn't change the the Active LOw setting in Mach3 as Actve High etc...
    I will request you to kindly help me making the Big-Tex version of Auto Tool zero setter seeing the above scenario and in METRIC unit...
    Your help in this regard is highly appreciated
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
  4. #124
    Has anyone put the toolchange probe macro in their M6 End macro?
    Doing that should alleviate the need to press the second button after a tool change. But I haven't tested it yet.
    I'm working on a new screen, and I'm incorporating this into it. I need to add tool change position DRO's, so the machine will move to a user defined location to change the tool, then pushing Cycle Start should finish the change by probing for the length, then continuing on.
    Doing some thinking (and testing) while typing this. Seems like I need the initial touch off button, but the second button just calls M6. This allows you to manually do a tool change after the initial touch off, but when running g-code, the tool change and length probe are handled automatically by Mach3.
    I haven't really read this thread that closely, so someone correct me if I'm wrong.
    Big Tex, seems like your installer did some undesirable things to my configuration. Last night, I ran your installer to check out how th macro's worked. This morning, when playing with the spindle rpm slider, I was getting PWM error messages. Seems your installer changed my spindle from step/dir to PWM, even though it was disabled?? It also seems to have enabled the Shuttle Pro plugin, as I got errors from that, since I don't have one?
    Can you confirm these are from your installer? Or did something really strange happen here??
  5. #125
    Nov 2007
    980
    Hi Gerry,
    I've seen this happen when installing other screen sets. I have no idea why but you're not alone here as I do not have the shuttle on my "design" PC, and it always seems to re-enable it when installing "some" screensets.
    I just delete the shuttle plug-in and it goes away, but still not sure how it gets there again to begin with. It may be a default plug-in being installed with this (and certain other) screensets.
    Dave
    Dave
    Dave->..
  6. #126
    Quote Originally Posted by Khalid View Post
    Hi big-tex,
    Khalid, it looks like you just need to probe in the other direction. You should be able to just change a few lines of code. Here's an example. These are in inches, you'd want to change the metric portions as well. There may be other changes need, but I don't have time to look through it thoroughly right now.
    Rem Probe In the z direction
    Code "F10" 'slow down feedrate to 10 ipm
    ZNew = GetDro(2) - 6 'probe move to current z - 6 inches
    Change to ZNew = GetDro(2) + 6
    Code "G31Z" & ZNew
    While IsMoving() 'wait for probe move to finish
    Wend
    ZNew = GetVar(2002) 'read the touch point
    Code "G0 Z" & ZNew +.1 'move back to hit point in case there was overshoot +.1
    Change to Code "G0 Z" & ZNew -.1
    While IsMoving ()
    Wend
  7. #127
    Apr 2006
    3498
    Thanks Gerry, I will change the values and will show the outcome
  8. #128
    Be aware that they need to be changed in several other places, and in both macros.
  9. #129
    Jul 2009
    272
    ger21
    Putting macro in m6start should work I have not tested it it that way since I do not have ATC.
    If you could add command to bottom of script for tool zero to proceed with start after touch off you will have single button operation. Is that doable?
    Cycle start Alt R shortcut dec. val 2131
    Installer does not change anything, it only installs set and jpeg files for graphic portion of screen set.
  10. #130
    Did some testing on my design PC.
    Looks like I can have M6 start move to a position to manually change the tool, then put your second macro in the M6 end, which gets executed after hitting cycle start.
    It's gonna take me a few weeks to get it setup to know for sure, but it sure seems like it should work fine, and save a step vs how you're doing it now.
  11. #131
    Jul 2009
    272
    What about inserting command to cycle start at the end of macro?
  12. #132
    Quote Originally Posted by Big-tex View Post
    You have to stop the spindle to change tools, so you need to click a button to restart it.
    If you set up General Config to "Stop Spindle, Wait for Cycle Start", then you only need to click Cycle Start after you change the tool.
    This seems to be the best way to me. Almost fully automatic. It moves the machine to where you want to change the tool, stops while you change it, and, after you hit cycle start, it re-zero's, and starts cutting.
  13. #133
    Apr 2006
    3498
    Its working fine for me Now Thanks Gerry and the Big-Tex.. This is for Metric Mode and special case of my Z-axis.. Please don't use unless your Z-axis Up and Down movement behave like my Z-axis......
    Rem This is for my MDF Machine for Milling
    Rem VBScript To probe In the z axis For G21 Only.. first Run the Gcode With G21 Then try Auto tool
    Rem My X,Y & Zaxis dirlowActive= High (Green) And steplowActive=High (green)
    Rem This Auto Tool Zero is For my inverted Z-axis Z-moves up= -ve , Zmoves down= +Ve
    If GetOemLed (825) <> 0 Then 'Check to see if the probe is already grounded or faulty
    Code "(Z-Plate is grounded, check connection and try again)" 'this goes in the status bar if aplicable
    Else
    Code "G4 P1" 'Pause 1 seconds to give time to position probe plate
    PlateOffset = GetUserDRO(1151) 'Get plate offset DRO
    CurrentFeed = GetOemDRO(818) 'Get the current feedrate to return to later
    Code "F100" 'slow down feedrate to 4 ipm
    Rem Probe in the z direction
    ZNew = GetDro(2) + 50 'probe move to current z - 2 inches
    Code "G31Z" &ZNew
    Wend
    Code "G0 Z" &ZNew 'move back to hit point incase there was overshoot
    While IsMoving ()
    Wend
    If PlateOffset <> 0 Then
    Call SetDro (2, -1*PlateOffset) 'set the Z axis DRO to plate thickness
    Code "G4 P0.25" 'Pause for Dro to update.
    ZNew = -1*PlateOffset - 5
    Code "G0 Z" &ZNew 'put the Z retract height you want here
    Code "(Z axis is now zeroed)" 'puts this message in the status bar
    End If
    Code "F" &CurrentFeed 'Returns to prior feed rate
    End If
  14. #134
    Jul 2009
    272
    ger21
    i want to retain functionality of cycle start and do not wish to change m6end
    what will execute command to start cycle that can be added to bottom of script
    code 2131
    does not work
  15. #135
    You're not changing cycle start at all. It still works normally.
    What happens, is that when Mach3 sees an M6 T2, it runs the M6 start macro, then waits for you to hit cycle start. When you hit cycle start, it runs M6 end.
    You set it up this way in general config.
  16. #136
    Cycle start should be DoOEMButton (1000)
  17. #137
    Jul 2009
    272
    I will test that see how I like it.
  18. #138
    Jul 2009
    272
    I guess there is more than one way to skin the cat.
  19. #139
    Jul 2009
    272
    DoOEMButton (1000)
    does not work, it appears as bug reported on mach 3 forum
  20. #140
    Jul 2009
    272
    ger21
    I have came across problem with my scripts and calc retract
    so I changed em to Code("G53G0Z-0.5") it is safer routine just in case something is in the way.
    It was rare situation but I felt like it needed changing. I will change metric section as well and post new version for download installer version.
    INITIAL ZERO SETUP
    Option Explicit 'Written by Big-Tex November 28 2010
    Dim xjobcoord
    Dim yjobcoord
    Dim xmachcoord
    Dim ymachcoord
    Dim zmachcoord
    Dim xprobeloc
    Dim yprobeloc
    Dim xtoprobe
    Dim ytoprobe
    Dim PlateOffset
    Dim CurrentFeed
    Dim ZNew
    Dim Zplate
    Dim Zrestposition
    Dim ZMaterialmachcoord
    Dim ZPlatejobcoord
    Dim Zplatetomaterial
    xjobcoord = GetDRO(0) 'get current job coordinate for X
    yjobcoord = GetDRO(1) 'get current job coordinate for Y
    xmachcoord = GetOemDRO(83) 'get current machine coordinate for X
    ymachcoord = GetOemDRO(84) 'get current machine coordinate for Y
    zmachcoord = GetOemDRO(85) 'get current machine coordinate for Z
    xprobeloc = GetUserDRO(1100) 'get X machine coordinate location of the touch plate
    yprobeloc = GetUserDRO(1101) 'get Y machine coordinate location of the touch plate
    xtoprobe = xprobeloc-xmachcoord+xjobcoord 'calculate the X move from the current location to the touch plate
    ytoprobe = yprobeloc-ymachcoord+yjobcoord 'calculate the Y move from the current location to the touch plate
    If GetOemLED(801) Then 'check if English Units
    If GetOemLed (825) <> 0 Then 'check to see if the probe is already grounded or faulty
    Else
    Code "G4 P1" 'pause 1 seconds to give time to position probe plate
    PlateOffset = GetUserDRO(1151) 'get plate offset DRO
    CurrentFeed = GetOemDRO(818) 'get the current feedrate to return to later
    Code "G31Z" &ZNew
    Wend
    Code "G0 Z" &ZNew +.1 'move back to hit point incase there was overshoot +.1
    While IsMoving ()
    Wend
    Rem End add lines
    Code "F2" 'slow down feedrate to 2 ipm
    ZNew = GetDro(2) - .25 'probe move to current z - .25 inches
    Code "G31Z" &ZNew
    Wend
    While IsMoving ()
    Wend
    Call SetDro (2, PlateOffset) 'set the Z axis DRO to plate thickness
    Code "G4 P0.25" 'pause for Dro to update.
    'ZNew = PlateOffset + 3.6315 'calc retract
    'Code "G0 Z" &ZNew 'put the Z retract height you want here
    Code("G53G0Z-0.5")
    While IsMoving ()
    Wend
    End If
    End If
    Else
    Zrestposition = GetDro(2) 'get the job cooridnate of the Z axis after setting Z
    ZMaterialmachcoord = GetOemDRO(85)-ZNew 'get current machine coordinate for Z & calc the top of the material for use later
    Code "G4 P1" 'pause for Dro to update
    Code "G0X" &xtoprobe &"Y" &Ytoprobe 'rapid to the location of the plate
    Rem Start Add lines To speed this up
    ZPlate = GetDro(2) - 6 'probe move to current z - 6 inches
    Code "G31Z" &ZPlate
    Wend
    ZPlate = GetVar(2002) 'read the touch point
    Code "G0 Z" &ZPlate +.1 'move back to hit point incase there was overshoot+.1
    While IsMoving ()
    Wend
    Rem End add lines
    ZPlate = GetDro(2) - .25 'probe move to current z - .25 inches
    Code "G31Z" &ZPlate
    Wend
    Code "G1 Z" &ZPlate 'move back to hit point incase there was overshoot
    While IsMoving ()
    Wend
    Zplatetomaterial = GetDRO(2) 'record the current coordinate of the bottom of the tool and plate
    Call SetUserDRO(1102,Zplatetomaterial) 'this sets a user DRO to the value of the top of material to top of plate
    Code("G53G0Z-0.5")
    While IsMoving () 'wait for probe move to finish retracting
    Wend
    Code "G0X" & xjobcoord & "Y" & yjobcoord'returns to the previus X Y job location
    While IsMoving()
    Wend
    Code "F" &CurrentFeed 'returns to prior feed rate
    Code "(Material Offset is Now Calculated in English Units)"'puts this message in the status bar
    End If
    Else 'this portion of script is for Metric Native Units
    Else
    Code "F300" 'slow down feedrate to 300 mmpm
    ZNew = GetDro(2) - 150 'probe move to current z - 150 mm
    Code "G31Z" &ZNew
    Wend
    Code "G0 Z" &ZNew + 3 'move back to hit point incase there was overshoot + 3
    While IsMoving ()
    Wend
    Rem End add lines
    Code "F50" 'slow down feedrate to 50 mmpm
    ZNew = GetDro(2) - 6 'probe move to current z - 6 mm
    Code "G31Z" &ZNew
    Wend
    While IsMoving ()
    Wend
    'ZNew = PlateOffset + 50 'calc retract
    Code("G53G0Z-20")
    While IsMoving ()
    Wend
    End If
    End If
    Else
    ZPlate = GetDro(2) - 150 'probe move to current z - 150 mm
    Code "G31Z" &ZPlate
    Wend
    Code "G0 Z" &ZPlate + 3 'move back to hit point incase there was overshoot+3
    While IsMoving ()
    Wend
    Rem End add lines
    ZPlate = GetDro(2) - 6 'probe move to current z - 6 mm
    Code "G31Z" &ZPlate
    Wend
    While IsMoving ()
    Wend
    Code("G53G0Z-20")
    Wend
    While IsMoving()
    Wend
    Code "(Material Offset is Now Calculated in Metric Units)"'puts this message in the status bar
    Code "F200"
    Sleep 100
    End If
    End If
    TOOL CHANGE ZERO SETUP
    Dim xjobcoord
    Dim yjobcoord
    Dim zjobcoord
    Dim xmachcoord
    Dim ymachcoord
    Dim zmachcoord
    Dim xprobeloc
    Dim yprobeloc
    Dim CurrentFeed
    Dim ZNew
    Dim ZPlate
    Dim PlateOffset
    Dim Zplatejobcoord
    Dim xtoprobe
    Dim ytoprobe
    zjobcoord = GetDRO(2) 'get current job coordinate for Z
    ymachcoord = GetOemDRO(84) 'get current machine coordinate for y
    zmachcoord = GetOemDRO(85) 'get current machine coordinate for z
    xprobeloc = GetUserDRO(1100) 'get x machine coord of fixed plate
    yprobeloc = GetUserDRO(1101) 'get y machine coord of fixed plate
    xtoprobe = xprobeloc-xmachcoord+xjobcoord 'calc x move to fixed probe
    ytoprobe = yprobeloc-ymachcoord+yjobcoord 'calc y move to fixed probe
    Rem Move To fixed In Plate location
    If GetOemLed(801) Then 'check if Native Units are English
    If GetOemLED(825)<>0 Then
    code "(Z-Plate Grounded Check connection and try again)"
    Else
    Rem Probe In Z direction
    Code "G0X" &xtoprobe &"Y"& ytoprobe 'move to fixed plate location
    Rem Start Add lines To speed up
    Code "F12" 'slow down feedrate to 10 ipm
    Zplate = GetDro(2)-6 'probe move to current z - 6 inches
    Code "G31Z" &Zplate
    While IsMoving()
    Wend
    Zplate = GetVar(2002) 'read the touch point
    Code "G1 Z" &Zplate+.1 'move back to hit point incase there was overshoot +.1 inches
    While IsMoving()
    Wend
    Rem End of add lines
    Zplate = GetDro(2)-.25 'probe move to current z - .25 inches
    Code "G31Z" &Zplate
    While IsMoving()
    Wend
    Zplatetomaterial = GetUserDRO(1102) 'get calculated material offset
    Call SetDRO(2,Zplatetomaterial) 'this sets Z DRO to calculated material offset
    'ZNew = PlateOffset + 2.6315 'calc retract
    Code("G53G0Z-0.5")
    Wend
    Code "G0X" & xjobcoord &"Y" & yjobcoord 'returns to the previous X Y job location
    While IsMoving()
    Wend
    Code "F350" '&CurrentFeed 'returns to prior feed rate
    Code "(Z axis is now zeroed in English Units)" 'puts this message in the status bar
    End If
    Else
    Zplate = GetDro(2)- 150 'probe move to current z - 150 mm
    Code "G31Z" &Zplate
    While IsMoving()
    Wend
    Code "G1 Z" &Zplate+ 3 'move back to hit point incase there was overshoot + 3 mm
    While IsMoving()
    Wend
    Zplate = GetDro(2)- 6 'probe move to current z - 6 mm
    Code "G31Z" &Zplate
    While IsMoving()
    Wend
    Code("G53G0Z-20")
    Wend
    While IsMoving()
    Wend
    Code "(Z axis is now zeroed in Metric Units)" 'puts this message in the status bar
    Code "F300"
    Sleep 100
    End If
    End If
    I have left original code so you can see where code was changed. You must remember that this code only operates correctly if you are NOT in machine coordinates.
    Gerry I hope that helps.
  1. Replies: 1
    Last Post: 03-04-2014, 01:08 AM
  2. Tool Length Offset Tool Setter
    By CNCneeds in forum News Announcements
    Last Post: 01-03-2014, 06:27 PM
  3. Tool Setter Macro for M-V60C and Metrol Setter
    By mitshack in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-02-2013, 12:08 PM
  4. Okuma Tool Setter Reference Tool
    By lisaclisac in forum Okuma
    Last Post: 09-28-2012, 03:21 PM
  5. Tool setter macro for M-V60C and Metrol setter
    By mitshack in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-06-2008, 02:38 PM
