585,931 active members*
3,680 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > Bent bar stock jams Iemca barfeeders on Star Swiss Machines
Results 1 to 11 of 11
    Mar 2010
    Hi All,
    We run 20 Star Swiss machines and we are constantly battling our bar stock suppliers for better quality. We typically have good luck on 5/16" and up, but on jobs that require say 1/4" Hex 303ss we end up with bars that are bent enough to cause problems. We developed an inspection process which rejects bars that we know will cause alarms, but the suppliers all say we are 'too picky' and that they can sell it to any of their other customers. Our spec is not nearly as stringent as what the bar feeder specifications call for either.
    What do you guys recommend?
    thanks
    Oct 2008
    108
    I would strongly consider another supplier. We have gotten to the point if the stock comes into the shop bent, we send it back, or ask for a discount for the bent bars.
    We also pay extra to have the load boxed to protect it. The bars don't come bent from the mill, they usually get bent by being mishandled at the warehouse.
    www.atmswiss.com
    Jul 2007
    82
    bar stock
    same problem in here, they load it on the truck like potatoes. First solution - new supplier (like MikeMc said), second - make them to send the bar stock in wooden boxes, third - well, if possible cut the stock by half and use it if first two solutions cannot help...
    Mar 2010
    Thank you for the replies. I agree that finding a new supplier seems like the best option, and we have indeed done this. Now it seems that every supplier in town is pissed at us for rejecting material that they claim is 'good'. We have had to switch to buying some high quantity stock straight from the mill to ensure good quality, but this option isn't possible on all materials due to the wide variety of sizes and shapes.
    Maybe I'll start a Minnesota thread dedicated to sharing supplier reviews and experiences?
    Jul 2007
    82
    bar stock
    we have two multispidle lathes on the floor, it took a while before we found out material was the problem (a lot of alarm messages and broken tools) but people making bar stock don't work with +-.0002 tolerance so they don't understand how important it is to have good stuff in your barfeeder. BTW - that new thread is not a bad idea...
    Mar 2008
    443
    Best solution to crappy material I ever found:
    http://www.schmolz-bickenbach.us/index.php?id=5251
    Well, for stainless steels anyhow.
    Jul 2006
    65
    Quote Originally Posted by PixMan View Post
    Met with a couple of their sales guys yesterday, about some possible inherent stress issues in some 304 (not in material from them). They were very helpful, and are sending in some sample stock, and hopefully it will solve today's problem.
    Oct 2008
    108
    Quote Originally Posted by pneumadyne View Post
    Let them be pissed, there is a straightness call out as well as a diameter call out on bar stock. If they damage the material beyond the industry standard, its their responsibility to take it back. All they need to do is train the people that work for them, the same as we do.
    Schmolz-Bickenbach does have great stainless, but they seem to be out of EVERYTHING, they just didn't order much when the economy turned. We had to go the Carpenter for most of our stuff now.
    www.atmswiss.com
    Mar 2008
    443
    As much as I always try to "Buy American", I've had nothing but frustration out of Carpenter. In my experience with using their high-end Project 70 303 stainless, their claim of being 'highest quality, most consistent' material is BS. I've gotten Project 70 303 that was all over the map on machineability.
    It's expensive, and IMO, just not worth paying for the marketing. That seems to be where the money is, not in true quality control.
    Sep 2005
    3
    With the economy down, you'd think suppliers would be doing a better job of listening to customer concerns.
    Until they do, are you using a press to straighten your bar stock?
    Also, I've heard of small straighteners consisting of four sets of rollers. Driven by fractional HP motor and bike chains.
    Two steel plates, sixteen bearings, eight shafts, five sprockets with various nuts and bolts and you're in business.
    Can't take much more time to fabricate than you're already losing on messing with the bent stuff.
    I can stop by if you like as I am in Bloomington.
    Hope this helps,
    Fin
    Mar 2013
    5
    Re: Bent bar stock jams Iemca barfeeders on Star Swiss Machines
    We have had some of the same problems so on some materials we have had to shorten the lengths of the material we receive. So on 1/2 round and below I believe we get in 12' lengths instead of 20'.
  1. G and M codes for Star swiss
    By elsanch in forum CNC Swiss Screw Machines
    Last Post: 01-07-2013, 12:23 AM
  2. STAR ECAS w/Iemca Genius 120?
    By ChristianK in forum CNC Swiss Screw Machines
    Last Post: 10-19-2012, 01:11 PM
  3. SWISS/STAR PROGRAMMER AVAILABLE
    By steve3three in forum Employment Opportunity
    Last Post: 09-07-2010, 01:06 PM
  4. New CNC Swiss machines from stock & Rep
    By npkaye in forum CNC Swiss Screw Machines
    Last Post: 10-02-2007, 05:02 PM
