Jet Edge’s 5’X5’ Mid Rail Gantry Waterjet System is an ideal water jet cutting solution for shops that cut smaller material or have limited floor space available for machine tools.
Powered by a 60,000 psi or 90,000 psi Jet Edge waterjet intensifier pump (available in 30-200hp models), the 5’X5’ water jet cutting machine features an exposed 72”X72” tank that easily accommodates overhead loading. It is designed to cut virtually any material up to 60”X60”. If equipped with an optional second cutting head, it can cut two parts up to 30”X60”. Optional mirroring cuts part cycle time in half.
The Jet Edge Mid Rail Gantry water jet system utilizes an industrial PC controller and can be configured so that all three axes are fully programmable (Z optional). It also features direct-couple AC brushless digital servo motors and single or double carriages. Critical bearing components are protected with heavy metal covers with brush seals. The Mid Rail Gantry waterjet system also is available in 8’x5’, and 21’x5’, 8’X13’ and 21’X13’ and 5’x13’ work envelopes.
Jet Edge’s Mid Rail Gantry Waterjet System is proudly made in the U.S.A. For more information, visit www.jetedge.com, e-mail [email protected], call 1-800-JET_EDGE (538-3343) or 763-497-8700.
About Jet Edge
Established in 1984, Jet Edge is a global designer and manufacturer of waterjet systems for precision cutting, surface preparation and coating removal. Jet Edge systems are used around the world in a broad range of industries, from the world's leading airlines to automotive, aerospace, industrial manufacturers, machine and job shops. Jet Edge waterjet systems are proudly made in the U.S.A.
More Information
For more information about Jet Edge, visit www.jetedge.com, e-mail [email protected] or call 1-800-JET-EDGE
(538-3343).
Information Request Form
